tazz9924 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None ![]() |
Im looking into converting my rear trunk to hydraulic shocks instead of the ultra scary torsion springs. I simply can have the torsion bars in place because they interfere with my engine. any replies welcome
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Camp 914
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
http://camp914.com/products.html
Buy the kit, not worth saving the $10 or so trying to piece it together yourself. If you source too soft or too strong springs you can damage your trunk. |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
I like to fabricate stuff myself, so I did my own with shocks from a pick-n-pull. Totally worth it to me because it was fun and saved me $40. I found an SUV that had separate shocks to open the window in the rear hatch door. The hatch door shocks would have been way too strong, but the ones for the glass were perfect.
if you aren't the fabricator type then the Camp914 kit is the only way to go. It's a ready-to-go kit solution, and Craig is a great vendor. |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
The new CAMP 914 rear trunk shox are the Gen2 with no cutting of any sheet metal and a much simpler installation.
Craig at CAMP Attached thumbnail(s) ![]() |
Mueller |
I like to fabricate stuff myself, so I did my own with shocks from a pick-n-pull. Totally worth it to me because it was fun and saved me $40. I found an SUV that had separate shocks to open the window in the rear hatch door. The hatch door shocks would have been way too strong, but the ones for the glass were perfect. if you aren't the fabricator type then the Camp914 kit is the only way to go. It's a ready-to-go kit solution, and Craig is a great vendor. A fabricator wouldn't have to ask how to do it, they'd do it (like you) or find a picture (IMG:style_emoticons/default/smile.gif) |
tazz9924 |
thanks for the replys ill check out camp 914. id usually just fabricate it myself but I didn't know where to start! (IMG:style_emoticons/default/confused24.gif)
tazz9924 |
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
Buy the Camp914 kit. Doesn't matter if you have Gen 1 or 2, you can do it without hacking up your trunk. Even I did it! Oddly enough....the Gen two looks my Gen 1 that I installed. :-)
Check my rear trunk shocks.... If you need exact measurements, let me know. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:00 AM |
