era vulgaris |
J is for Genius ![]() ![]() ![]() Group: Members Posts: 983 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States ![]() |
I'm trying to find the grommet that goes on the taco plate, that the sender wire passes through. I looked through 914rubber and Pelican's sites, but couldn't find them. Maybe I missed them. Is anyone making these? If not, what are you guys using?
Attached image(s) ![]() |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,843 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
AA
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,759 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I've got one I made for the license plate light wires. May work. PM me your address I'll drop one out to see if it fits.
Mark |
McMark |
Part number 311 949 149 A
Appears to be available from VW/Audi dealers, but I can't find any pictures to confirm. |
era vulgaris |
Thanks guys! Mikey914, I sent a pm.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
That is a type 4 (411,412) part number, A regular beetle through the chassis brake line grommet (211 611 751) fits the big hole perfectly, but the wire hole is a little big. A small section of shrink tube or small hose would make up the difference.
A couple bucks for four at any AC VW shop. Attached image(s) ![]() |
Mikey914 |
Think mine will be a perfect fit, but may want to slit it to install the wire.
It's a very sturdy grommet. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,087 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
The 311 part has a nipple on the end. I don't have one for a picture.
Mikey914 |
Well tried mine, too big. I'm trying to source, but if not I will make.
Mark |
clapeza |
Member ![]() ![]() Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States ![]() ![]() |
Sorry to hijack, but what about the CHT engine tin grommet? Now that 914Rubber sells a replacement CHT, stocking the grommet would be a natural addition.
I did a search, and got several "it's still available" and try vendor X, but I'm much more likely to order more stuff from Mark than anyone... Any chance this is on the "to-do list"? |
JFJ914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States ![]() ![]() ![]() |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
How about the Assortment pack of faucet washers at Ace hardware? They also have a nice assortment of rubber washers
Mikey914 |
Mikey914 |
Sorry to hijack, but what about the CHT engine tin grommet? Now that 914Rubber sells a replacement CHT, stocking the grommet would be a natural addition. I did a search, and got several "it's still available" and try vendor X, but I'm much more likely to order more stuff from Mark than anyone... Any chance this is on the "to-do list"? DO you mean this? Yes I have obtained a sample and it is on the list maybe 6-8 weeks at this point. I do want to thank those of you that do buy parts from me. As you know I do roll the proceeds back into making more parts and supporting the community. I often do make improvements in materials and other design features only where it makes sense (basically I prefer as close to stock as possible). Your purchases allow me to make more parts, and take on some very large projects. SO thanks to all that are supporting our efforts!!! (IMG:style_emoticons/default/beerchug.gif) Attached image(s) ![]() |
Lo-Fi Version | Time is now: 10th March 2025 - 04:30 PM |
