Rattle noise, bag of nails in the engine |
cal914 |
Jun 21 2016, 01:38 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
I recently had our 1.7 serviced and they reset the gaps in the tappets but now the engine seems to make a rattle noise now,something it didn't do before hand they are experienced so i doubt that they set the wrong gaps but somethings changed
Thanks Brian |
Rand |
Jun 21 2016, 01:41 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Sounds like they don't know the right specs and got some way too loose. Ask them if they know what should be .06 vs .08 and if they know which 914s had engines that needed different specs.
Bob L. |
Jun 21 2016, 02:15 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Does it quiet down after warming up?
76-914 |
Jun 21 2016, 02:18 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
That or they gapped chromoly rods, unwittingly. Also, check your heat exchanger for a loose fit or some tool left on top of an exchanger.
cal914 |
Jun 21 2016, 02:29 PM
That or they gapped chromoly rods, unwittingly. Also, check your heat exchanger for a loose fit or some tool left on top of an exchanger. The noise is defiantly coming from the engine , when I spoke to the guy he said that the gaps where really tight could that mean that they are chromoly rods (what ever they are ) Thanks Brian |
TheCabinetmaker |
Jun 21 2016, 02:55 PM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock
barefoot |
Jun 21 2016, 03:22 PM
Senior Member Group: Members Posts: 1,318 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock Sodium filled push rods ???, mine are just just aluminum with open ends. |
r_towle |
Jun 21 2016, 03:58 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Doubt the push rods were replaced, just bring it back it may just need to be done again...
Mark Henry |
Jun 21 2016, 04:45 PM
Brian, chromoly pushrods do not expand like the stock sodium filled rods. They are adjusted at zero lash. The ends of the rods are very different from the stock, so easy to tell if they are not stock. that doesn't mean they are chromoly, just means they are not stock Sodium filled push rods ???, mine are just just aluminum with open ends. Yep.... OE 2.0 exhaust valves are sodium filled. |
stugray |
Jun 21 2016, 05:28 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
He said pushrods.
the pushrods are not sodium filled but the valves are. In fact they are hollow so they can pump oil to the rockers. |
mepstein |
Jun 21 2016, 05:44 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Check the fan
TheCabinetmaker |
Jun 21 2016, 07:53 PM
Stu is correct. Sodium filled valves. Not sure what I was thinking.
Lo-Fi Version | Time is now: 27th September 2024 - 12:48 PM |
