BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Looking to purchase some metal sections for my project. If you've got a parts car with solid sections of the following that you can cut and ship to 20165, please let me know:
1. Need the front trunk (frunk) section that approximates the section I have highlighted in red below. That red box is sort of the "minimum" that I need. ![]() 2. The rear trunk section for a '75. I could buy the Resto Design section for this, but it requires some decent modification to fit a '75. if you have a section with the minimum amount shown below and are willing to cut/ship, let me know: ![]() Thanks! rob |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
I should have a front trunk pan section I cut out of a parts car. I will check it out tomorrow morning and make sure it covers the area you need. Will post a few pictures here tomorrow.
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
Rob, I think you'll be ok with the RD piece. Looks like you only need the center section. The ends are the portions that need to be reworked.
Just make sure to fit the back first. So it's tight against the tail light panel. |
BeatNavy |
I should have a front trunk pan section I cut out of a parts car. I will check it out tomorrow morning and make sure it covers the area you need. Will post a few pictures here tomorrow. Awesome, thanks Garold. If the piece you have doesn't quite cover all that red box area I should still be ok, provided it gets most of the back. There's a lot less rust up on the forward part (and more in the back, as evidenced by the big gaping hole). Rob, I think you'll be ok with the RD piece. Looks like you only need the center section. The ends are the portions that need to be reworked. Just make sure to fit the back first. So it's tight against the tail light panel. Hey Cary, I was wondering about that. Then maybe I'll go ahead and get the RD piece. Question for you - I haven't really thought about it too much, but if I'm planning on backdating the bumpers on this and end up removing those bumper shocks, would the whole rear RD piece fit without mod at that point? Thanks guys! |
GaroldShaffer |
here is what I have. Looks like it should work for you front trunk.
Attached image(s) ![]() ![]() |
BeatNavy |
Looks like a big winner to me, Garold. I'll send you a PM.
I went ahead and purchased the RD piece for the rear trunk. Now I can have frunk 'n trunk taken care of. Thanks again, fellas. |
cary |
Hey Cary, I was wondering about that. Then maybe I'll go ahead and get the RD piece. Question for you - I haven't really thought about it too much, but if I'm planning on backdating the bumpers on this and end up removing those bumper shocks, would the whole rear RD piece fit without mod at that point? Should have no issues. Corners need a little fiddling, but pretty straight forward. You need the couple pieces in the yellow circle below. ![]() ![]() Biggest issue is whether to install a new tow hook receiver or not. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:17 PM |
