NoEcm |
Member ![]() ![]() Group: Members Posts: 95 Joined: 20-June 05 From: Seattle, WA Member No.: 4,309 ![]() |
I have a leaking pressure switch on the master cylinder and I need to purchase a single pole one for a '75.
Is this part available separately? |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
The single pole switch grounds through the switch case, where the two pole requires a separate ground wire to the chassis if you need to use it.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I should have a NOS one if you want it. Can check later today. $18 shipped.
NoEcm |
NoEcm |
I purchased a new switch and now for the installation.
From the drawings I see that there is an O-Ring between the switch and master cylinder. I also see that the O-Ring is NLA. Is this just a common O-Ring that I can purchase at a hardware store? |
Lo-Fi Version | Time is now: 26th June 2024 - 02:30 AM |
