Cracker |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States ![]() ![]() |
Has anyone ever experienced a torsion bar failure? At speed? If so, please, how did the car react and how severe was it? Also, if you have broken a bar - was it stock or aftermarket? I couldn't find an applicable thread...thanks.
T |
Perry Kiehl Clone |
Unregistered ![]() |
You'll hear a big bang or cracking sound, that side of the car will droop really bad, and handling will be dangerous.
Cracker |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,287 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Had one break many yrs ago, can't remember if while it sat, or driving.
When the rear rubber bushing sags, the bar now starts scraping the ID of the A-arm which wears thru the protective coating, then leading to corrosion and subsequent fatigue failure initiated along a corrosion pit. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,126 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
The oppostite rear side will be way high.
malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I would say the tire would hit the inside of the fender and steering would be tuff.
Recently pushed a tub with one bar missing on to a trailer. Had to back it on 'cause nothing, including the U-Haul straps, would fit around the front tire. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,343 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
The 911 guys break them all the time. We have proof in the shop. Stock and aftermarket. Mostly older bars that have a little rust and a little wear/rubbing.
Lo-Fi Version | Time is now: 2nd July 2024 - 09:05 PM |
