E brake handle removal, I'm stuck |
EdwardBlume |
Aug 24 2016, 02:52 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I need to take the e brake handle completely off but the cable assembly doesn't fit through the tunnel and the lever side pin seems frozen on. The picture is of me using PB Blaster and a grip to apply pressure to the pin but it's not budging.
Any ideas? Attached thumbnail(s) |
EdwardBlume |
Aug 24 2016, 02:54 PM
Another
mepstein |
Aug 24 2016, 02:59 PM
914-6 GT in waiting Group: Members Posts: 19,679 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Cut the cable. Remove the parts. R&R the parts. Buy a new cable.
76-914 |
Aug 24 2016, 03:02 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,650 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Have you tried the torch yet?
EdwardBlume |
Aug 24 2016, 04:28 PM
EdwardBlume |
Cut the cable. Remove the parts. R&R the parts. Buy a new cable. Can't afford it right now. (IMG:style_emoticons/default/dry.gif) |
EdwardBlume |
Aug 24 2016, 04:47 PM
Got lucky...
mepstein |
Aug 24 2016, 05:02 PM
Good (IMG:style_emoticons/default/smile.gif)
EdwardBlume |
Aug 24 2016, 05:06 PM
Little bit of paint....
Tburt52359 |
Aug 24 2016, 07:16 PM
Newbie Group: Members Posts: 49 Joined: 24-May 15 From: Orange County Member No.: 18,756 Region Association: Southern California |
Ok. I'm having the same problem. How'd you get it off??? Heat and PB Blaster??? Please share! Cheers. (IMG:style_emoticons/default/beer.gif)
iankarr |
Aug 24 2016, 07:33 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,528 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
On mine, the pin rusted solid to the lever. I used a dremel with a grinding wheel to flatten the head, put a punch in the center and drilled it out. Worked perfect and was able to save all the original parts. Make sure you buy the correct length pin when it's time to reassemble. I got some from AA that were too short. But that's what I get for ordering from AA. I'm smarter now (IMG:style_emoticons/default/wink.gif)
Tburt52359 |
Aug 24 2016, 07:39 PM
Thx!
mepstein |
On mine, the pin rusted solid to the lever. I used a dremel with a grinding wheel to flatten the head, put a punch in the center and drilled it out. Worked perfect and was able to save all the original parts. Make sure you buy the correct length pin when it's time to reassemble. I got some from AA that were too short. But that's what I get for ordering from AA. I'm smarter now (IMG:style_emoticons/default/wink.gif) I think PMB carries all the correct pins and clips. |
914forme |
Aug 24 2016, 08:03 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
I was not as lucky so I cut all the spot welds off the cable cover guide on the lower portion did the R&R then re-assembled. And welded it back in place.
EdwardBlume |
Aug 24 2016, 09:34 PM
The other pin just came out. Kind of a bear to do, and then I noticed the carpet kit doesn't require the removal (IMG:style_emoticons/default/headbang.gif)
I'm working on a cool solution. I'll post it if its successful. (IMG:style_emoticons/default/shades.gif) |
EdwardBlume |
Aug 25 2016, 12:39 PM
Leather wrapped e brake handle!
EdwardBlume |
Aug 25 2016, 12:42 PM
I stitched up a length of leather, made it a tube, inward sewed the top around the button, and tapered the other side. 3M adhesive on the inside. Should work just fine. The stitching is on the finger groves. (IMG:style_emoticons/default/aktion035.gif)
Whitney Mic |
Aug 28 2016, 01:44 PM
What sort of chicanery is this? Group: Members Posts: 98 Joined: 29-June 16 From: Santa Cruz, CA Member No.: 20,157 Region Association: None |
Leather wrapped e brake handle! Have you had anyone up from the Physics Department at UC Berkeley to investigate the apparent warp in gravity localized to the "wall" of your garage? (IMG:style_emoticons/default/laugh.gif) (I had only scrolled far enough to see the leather handbrake cover and noticed the car seat 'hanging on the wall' before I realized the pic was sideways. The (IMG:style_emoticons/default/laugh.gif) is for my mistake!) The handbrake looks great. I want to see it all back together now. BTW, "Good luck, we're all counting on you." -- Whit |
Lo-Fi Version | Time is now: 5th January 2025 - 12:37 AM |
