Targa Horizontal Trim, how do you remove? |
STL914 |
Apr 16 2005, 01:53 PM
Senior Member Group: Members Posts: 1,183 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
I need some HELP!!
I'm removing the aluminum targa trim from my car, both vertical pieces are off. Is there some trick to removing the horizontal piece from the targa bar? Do I need to delicately pry it from some mounting tabs? I did a search on the site with no luck, so I decedied to post a request for help from you guys . Thanks, |
Porsche Rescue |
Apr 16 2005, 02:37 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
It is held on with 3 or 4 spring clips. You carefully pull/pry straight back to the rear of the car.
McMark |
Apr 16 2005, 04:21 PM
jasons |
Apr 16 2005, 07:14 PM
Jackstand Extraordinaire Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
You can actually reach up through the rear wheel well and pinch the clips so they pop out easier. You may not be able to do this for the one closest to the door however.
STL914 |
Apr 17 2005, 10:57 AM
Thanks guys, I got it done! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 26th December 2024 - 06:05 AM |
