jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
I need to paint the interior of some metal planter boxes with something that will seal them (they are not 100% watertight) and protect them. There was something like that one one of those "as seen on TV" type commercials I am thinking of.
What would all ya'll recommend? I want something I can just paint on and forget, no two part things. |
zambezi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States ![]() |
How about a truck bed liner. It fills holes and makes a continuous leak proof coating.
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
A 2 component fluid applied is what you are looking for, stay away from anything 1 component, they do not last.
If it were me I would just go get some Bituthene or similar which is a self adhered sheet membrane and be done with it. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Do you want them to be water tight?
If you do Gacoroof would be perfect, but I think 1 gallon is the smallest size you can buy. There may be a similar product that's cheaper. It's also 1 part. http://www.worldofstains.com/GacoRoof-Coat...oof-1-white.htm If you have an RV the rest could be used on the roof. (IMG:style_emoticons/default/shades.gif) Gacodeck (same stuff in colours) on our decks for 3 years, holding up great and no leaks. |
sb914 |
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,323 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California ![]() ![]() |
You need drainage!
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
What are you planting? As noted, you need drainage. Put some gravel in the bottom, maybe a piece of landscape fabric on the gravel and call it good to go.
The product in the commercials where the guy waterproofs the row boat is expensive. Very, for the amount you get for your money and the surface has to be 'just so'. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Zinsser Watertite ,great product comes in white but can be tinted,not easy to apply as its like honey....very thick.
rhodyguy |
You never know what might stunt or kill the plants. The brush will be trashed too. you can prob buy a 5 gal bucket of gravel from a landscape supply for a couple of bucks or if like me, I scrape it out of my driveway. You'll only need a few inches in the bottom.
MLedesma |
Member ![]() ![]() Group: Members Posts: 52 Joined: 13-October 06 From: Elizabeth, CO Member No.: 7,036 Region Association: Rocky Mountains ![]() |
Try Dial submarine cooler coating. Stuff is made for evaporative coolers. I coated the inside belly of mine 8 years ago and haven't had an issue. Takes a while to dry and smells bad. Comes in Quart size for around $10.
rhodyguy |
The belly of what? A boat?
MLedesma |
The belly of the evaporative cooler also known as a swamp cooler.
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
rhodyguy |
That's the one you need read the instructions for use before you buy it. There is cleaning/degreasing/scuffing the area to be coated with sandpaper/multiple coats and dry times involved.
jeffdon |
Back for some help with this project. Making more planters. Bigger now, but no bottoms, as they sit over open ground. 1" angle iron with 16 gauge steel. I MIGGED the sides in using a spiral pattern (as opposed to just welding in straight lines) and am getting bad oil canning.
My question is about shrinking the panels to make them tight. Whats the best way. Heat with a torch? Shrinking disk ? |
Lo-Fi Version | Time is now: 26th June 2024 - 01:16 AM |
