What does this wire go to? |
surfdogskier |
Oct 5 2016, 12:19 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Can anyone tell me what this wire went to? It was located around the cold start plug. I was trying to see what it went to and ended up breaking off the wire and the plug. It is a large plug. I wonder if this thats something to do with my car not starting. The wire looks to be white or beige. There is another wire that is connected to some below this one that looks to be the same size.
My haynes porsche book isn't worth a crap trying to find out this stuff. Thanks in advance! Attached image(s) |
914fahrer |
Oct 5 2016, 12:53 PM
Member Group: Members Posts: 103 Joined: 12-November 14 From: Berlin/Germany Member No.: 18,115 Region Association: Germany |
Check the connection to the cylinder head temp sensor and or the thermotime switch. Both have this plug.Perhaps this helps http://bowlsby.net/914/WiringHarnesses/HarnDia_FI_W71-72.jpg |
914_teener |
Oct 5 2016, 01:14 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
If that is a D-jet car and the CHT lead is disconnected....unless it is connected to ground....the car will not run.
surfdogskier |
Oct 5 2016, 01:51 PM
surfdogskier |
Oct 5 2016, 01:52 PM
Check the connection to the cylinder head temp sensor and or the thermotime switch. Both have this plug.Perhaps this helps http://bowlsby.net/914/WiringHarnesses/HarnDia_FI_W71-72.jpg Thanks for the link! I am goin to print this and keep it for future reference. |
Valy |
Oct 5 2016, 02:08 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
If it's a brown wire, it goes to ground on one side. Just find out where the other end goes...
smg914 |
Oct 5 2016, 02:11 PM
Sahara Beige Steve Group: Members Posts: 1,970 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
The missing connection should go to the AAR. Auxiliary Air Regular
smg914 |
Oct 5 2016, 02:20 PM
The RED wire is what you should be looking for.
Attached image(s) |
malcolm2 |
Oct 5 2016, 02:29 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
It is tuff for the forum to help with wiring. You are going to get 100 different ideas. If one end of that wire has a connector on it, look for the female (or male) part somewhere very damn close to it. If it is brown there might be a hidden case bolt with 4 or 5 spades on it that are all grounds, they should all have a wire on them, if one is missing.... TA DA. short of that......
I sing this guys praises every chance I get. The one I bought is not EXACTLY perfect, but it is a HUGE help. PROSPERO'S GARAGE LINK for $20 even an electrical illiterate like me can get things done. Look for your car in the list and buy one today. |
76-914 |
Oct 5 2016, 02:52 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,650 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Caution: exposed "old" red wires turn BROWN with age. (IMG:style_emoticons/default/beerchug.gif)
Dave_Darling |
Oct 5 2016, 04:33 PM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The CHT does have that type of connector on it. So does the sender for the oil temp. But the one in the area you mention just about has to be the one for the AAR, as SMG posted.
--DD |
TheCabinetmaker |
Oct 5 2016, 05:10 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I agree with Dave and smg. Only connector insulator like that in that area. If it grounds it blows the fuse on the relay board and the pump won't run. The aar wire just simply unplugged will not keep the car from running unless it shorts.
Malcolm, this forum is generally amazing with electrical diagnosis! |
malcolm2 |
Oct 5 2016, 06:44 PM
Malcolm, this forum is generally amazing with electrical diagnosis! Hope no one was offended.. But a good diagram can't be beat. And i have found that while pictures say 1000 words… Sometimes you are on your own for a few days. I am always thankful for help, and options, who would'nt be? |
pbanders |
Oct 5 2016, 10:28 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
If that is a D-jet car and the CHT lead is disconnected....unless it is connected to ground....the car will not run. Mine is a d-jet. Maybe this has been my issue all along. Thanks! My page (in my sig) has detailed D-Jet troubleshooting information. If your car isn't running, don't assume it's the FI. For the car to start, basic mechanical (compression), electrical (battery voltage), ignition (spark when cranking), fuel supply (pressure when cranking), BEFORE going after the FI. Make sure you have all of the parts of the FI system, the harness is connected correctly to the FI components, and that you have done basic checks on each of the components (see my page). Use a noid light (Amazon) to check that you have signal at each of the injectors, and if necessary, pull the injectors and verify that they're spraying fuel. |
Lo-Fi Version | Time is now: 5th January 2025 - 01:45 AM |
