> which door end caps to use?, different models found online
Frankvw
post Oct 17 2016, 07:22 AM
working on my first 914 !
Region Association: Europe
Hi, I miss the door end caps on my 1973 1.7
and the other side as well
I found two types online as replacements, I am not sure which one I need since that is not clearly stated on the different sites I find them?
Can somebody tell me which ones should be installed on my 73 ?
Thanks a lot for your feedback!
rgalla9146
post Oct 17 2016, 07:52 AM
Pretty sure you'll need the later version.
The attaching screw is on the outside of the door and the glass slot is round.
The earlier one is fastened inside the glass slot and the glass slot is square.
rhodyguy
post Oct 17 2016, 08:51 AM
Replace the fuzzy channel pieces while you're in there. Make vapor barriers out of 6mil plastic.
Cal
post Oct 17 2016, 09:09 AM
....dumb question....are the attaching screws for the end caps phillips head or flat head type? I've seen both types on various cars.
Frankvw
post Oct 17 2016, 09:50 AM
I have a philps scew in there. Not sure if that is correct...
@rgalla9146:
"Pretty sure you'll need the later version."
That would be the left one in the pic?
Thanks in advance!
Mikey914
post Oct 17 2016, 10:18 AM
The rubber man
Late
You need these
http://shop.914rubber.com/914-Late-door-en...ght-914LDEC.htm
Also pick up the correct scrapers while you are there.
http://shop.914rubber.com/914-Early-Outer-...ion-914ODSE.htm
Mikey914
post Oct 17 2016, 10:19 AM
The rubber man
Also screw should be phillips
Also made mine out of rubber not plastic so they will not break like the OEM
914fahrer
post Oct 17 2016, 10:25 AM
Region Association: Germany
Your old Cap at the Car are the later one.The correct srew is B2,9x6,5 with a oval head.
(Linsenkopfschraube in german)
Cal
post Oct 17 2016, 11:08 AM
QUOTE(Mikey914 @ Oct 17 2016, 12:19 PM) *
Interesting....these two low mileage cars are showing flat head type.
JawjaPorsche
post Oct 17 2016, 11:13 AM
Mine is stock. Original owner. Phillips head.
Frankvw
post Oct 17 2016, 12:22 PM
Thanks all for your advice and tips !
- Lo-Fi Version Time is now: 21st December 2024 - 09:28 PM
