malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I thought I had commented on a post a few weeks ago about a 4-way connector the poster was using to attach a VDO OP sender and a OEM OP sender. He had plugged the 3rd outlet, but I want to use the 3rd outlet to attach my mechanical OP gauge to view inside the engine bay.
I cannot find that post. I have searched the World over and just can't find it, with or without my supposed comment Does anyone else remember it? Clark |
McMark |
Pipe thread will work. Off to Home Depot!
malcolm2 |
I have all that. I liked the look of the 4 way. It was aluminum (sliver at least). It had a mounting hole to help make sure it was grounded. Each outlet (or inlet) had the thread size marked.
It was really cool, vs. my current hodge-podge bunch of brass. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
malcolm2 |
both are nice and I remember the 2nd one.....
but the design 42 one is the one I wanted, it is a 4-way. What I have found and want to stop from happening is the LITE connection on the VDO sendor fires up the light at 10 psi. IIRC the OEM one is lower.... like 6 psi. http://www.42draftdesigns.com/vw-audi-oil-...relocation-kit/ Thanks a TON> |
malcolm2 |
What is up with SEARCH....? I did a search for me with the word "oil" in Garage and in all forums. it returned SORRY, nothing found.
Yet if you go to the post mentioned 2 times above, I find my post and the fact that I typed the word "oil". What is up? |
stugray |
What is up with SEARCH....? I did a search for me with the word "oil" in Garage and in all forums. it returned SORRY, nothing found. Yet if you go to the post mentioned 2 times above, I find my post and the fact that I typed the word "oil". What is up? For some reason you cannot search any word with just 3 characters (Like VDO, CHT, EGT, etc) |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
That first pic is my car. Love the 42 designs setup. Keep in mind that the other port is M10...not NPT...so you may need an adaptor
Search-wise, I just use google, prefacing everything with 914world. Seems to work great. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:38 AM |
