914ltd |
Member ![]() ![]() Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
Anyone have a fix for the folding park brake handle release spring? This is the flat leaf welded to the rod that pushes the ratchet pawl.
I think it would be a good enterprise for someone to create. I actually like the folding handles, you can leave the engine running parked on Main street and between the illogical park brake and the fact it is a manual shift car no one could steal it. Brad Attached image(s) ![]() |
RAX914 |
Member ![]() ![]() Group: Members Posts: 100 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None ![]() ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Spring is not hard to make, attaching the spring to the rest of the mechanism will require a tac weld.
walterolin |
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States ![]() |
FWIW I was able to braze mine with MAP gas. Tricky booger to put back together and hold inplace while you put it in.
McMark |
The factory ones are welded. I played around with forming spring steel on another project recently, and had some success. I wonder if McMaster has the correct thickness and width material to start with.
The one on my Turbo car is busted as well and I need to fix it. |
rudedude |
Senior Member ![]() ![]() ![]() Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest ![]() ![]() |
I remember using a hacksaw blade that still is working years later
Localboy808 |
Member ![]() ![]() Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None ![]() |
Anyone have a fix for the folding park brake handle release spring? This is the flat leaf welded to the rod that pushes the ratchet pawl. I think it would be a good enterprise for someone to create. I actually like the folding handles, you can leave the engine running parked on Main street and between the illogical park brake and the fact it is a manual shift car no one could steal it. Brad I may have a good folding handle I could sell you. I bought one to replace mine thinking it was broken. Not knowing all I needed was the missing piece with the teeth that mounts below the handle. Send me a PM if you are looking to buy one and I can shoot you some pictures. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:26 AM |
