> Exhuast leak..., Fix for 6 minutes?
wrpspddrvr
post Apr 22 2005, 05:30 PM
Hi all. Got my car inspected the other day, and it failed because of the exhaust leak. Turns out the exhaust leak is because the tits with the threads that hold the studs are broken off, so I'll need a new head to fix it properly.
Anyway, I'd like for my car to pass, so is there something I can do to seal the hole just for 5 minutes of running? The shop is a 30 second downhill trip from my work, so I thought I could do the fix and then roll down the hill to the shop, and it would only have to be started long enough to get in the garage, get looked at, and get the sticker put on. After that, I don't care. Once it's got the sticker....
Anyway, I was thinking about some red silicone or something? Just something to stop the noise for 5 minutes. Any thoughts? Maybe some tin can JB welded to the head and to the manifold? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Thanks!
Cole (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif)
eeyore
post Apr 22 2005, 05:57 PM
Would a C-note wrapped in nomex work?
Fixing a stud is painful enough. Undo a quick fix would make it worse.
Dr. Roger
post Apr 22 2005, 07:15 PM
A bat out of hell.
Hmmmm,
Is the inspector doesn't mind smelling burning JB weld... that stuff is bullet proof unless you apply 1.000 degree heat..... then it catches fire.....
In another life I once used flame proof cloth, a tin can and some tie wire strategically placed did the trick..... on a street bike... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
JB 914
post Apr 23 2005, 07:43 AM
Daddy! Finish my car NOW!!!
http://www.por15.com/product.asp?productid=7
This might work too. of course i'm sure it would be a bitch to get it off once it cured (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
- Lo-Fi Version Time is now: 4th January 2025 - 06:55 PM
