slivel |
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 512 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California ![]() |
In between watching the crummy coverage on CBS of the San Marino Grand Prix, I installed Boxster monoblock brakes on the 914.
Attached image(s) ![]() |
slivel |
Another view.
slivel |
Last one.
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
show us the adapters please (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
BTW - what do 4 boxster calipers go for lately? |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
I'm cured! I actually have (nearly) a full erection! (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) M |
slivel |
The adapters are shown in the photo. I think that they are available separtaely from Racers Edge but I bought a package from Paragon Products (talk to Jason). You wouldn't want 4 Boxster calipers - just the fronts. I am using Carerra rears.
wrpspddrvr |
Member ![]() ![]() Group: Members Posts: 333 Joined: 22-December 04 Member No.: 3,317 Region Association: None ![]() |
So you used Mueller's adaptor hub thingies with the Boxster kit? MORE INFO PLEASE!! Woo! (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
I plan to buy a set of these as soon as eComm goes up. I was looking to do the same thing you're doing. Cole (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
Aaron Cox |
wrong. bolt spacingss are different. boxster kit is also 1 grand.... and you need 911 3.5" struts..... so your better off going a whole 911 front suspension... |
wrpspddrvr |
Damnation. I swear I saw some adaptors to fit a 3.5" caliper on a 3" bolt hole spacing somewhere..... Don't the early assdragger guys do that? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Oh well, looks like I'll just stick with M calipers and some fancy rotors and pads. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Cole (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
well yea... VCI does it.. as do others |
slivel |
Aaron's right, you need 3.5 inch spacing to fit the adapter. Early 911 struts have this. The Boxster calipers fit Carerra rotors. In Aaron' s case he already has M brakes so he has the proper spacing.
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
Righ Johnson sells a complete setup for all for corners
Why would you not want four boxter calipers? I have all four on mine |
Aaron Cox |
nope. M calipers are 3" spacing. same as 914 calipers. early cars with S calipers have 3.5, and later cars with A calipers have 3.5.... |
slivel |
I should have been more clear in my response - you wouldn't want to use the fronts all around. If you have the complete set of fronts and rears then you are fine. You will probably need to go with a 23 mm M/C though.
slivel |
Aaron, yes you are right again. My mistake - sorry. 3 inch for the M's.
echocanyons |
Wheww... I havent driven mine yet and was under the impression that they would be fine. |
Maltese Falcon |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
I've done the 986 F & R caliper install on 2 sixes last month, with the 19mm mc...with a noticeable braking improvement. I know of one 9146 with 986 rear calipers all-around, and the owner (Dave @ TRE) says it's the best set up for his street/ track car. I still prefer the F and R set-up. I'll prolly go to the tilton or wilwood proportioning valve next.
JB 914 |
Daddy! Finish my car NOW!!! ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 ![]() |
are the Boxter rotors different? or do those calipers work with the same 911 rotors?
slivel |
The Boxster calipers work with standard 24 mm Carrera rotors.
Lo-Fi Version | Time is now: 29th June 2024 - 01:48 AM |
