dgraves |
1974 914 2.0 ![]() ![]() Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains ![]() |
Has anyone had any experience with installing a Heater Blower Update Kit; 914 1970-76 from the Auto Atlanta website? Was there a noticeable improvement in the heat and defrost output? Thank you.
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Is that the fan attachment for two hoses?
If that's what they're doing and I'm not sure what the kit includes you could probably buy those parts off the members here for less Post a link a description or some pictures |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
If I recall, it's a spliter and hoses.
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
When we were in Montana and the boys drove both cars everyday I fabricated brackets and ran duel fan motors.
Tried the splitter first. A bit better, not enough. |
dgraves |
Thanks, everyone. It is a splitter for engine compartment fan.
bandjoey |
Post in the classifieds and you'll find the splitter I'll bet. hose is available at FLAPS or perhaps 914rubber.com.
http://www.914world.com/bbs2/index.php?sho...8&hl=heater here u go. this one is sold but there are others out there. post away (IMG:style_emoticons/default/biggrin.gif) |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,629 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Not sure exactly where it is but I have the splitter. Never put it on. Bought it used from a member. (IMG:style_emoticons/default/evilgrin.gif)
3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
Just my $.02, but from my experience in sunny AZ & NM, a single rear fan motor on my 2.0L didn't work that great. I ended up doing dual fan motors (one one each side feeding into the J-pipe) and the result was decent. It would defrost the windshield quickly.
Good luck. |
Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 705 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
I'd like to find out what the CFM output of the stock fan is. I would like to run dual fans eventually as well.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
The splitter sort of works, but the stock fan really doesn't have enough CFM for two hoses. Dual fans would be better. I don't know what the draw on one fan is, but to be safe you should switch the 2nd fan with a separate relay.
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,682 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Where and how did you guys mount the second fan?
Pics would be nice also. |
carcus |
Member ![]() ![]() Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains ![]() |
Gets below zero quite a bit here and I have not had an issue with the stock setup. Sometimes it will burn my face off and have to pull the knob off. I just wear a jacket and jeans. I think the best thing for me was new rubber on the T tops and doors.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Your 914 has t tops?
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
if you want dual fans & want to get fancy (IMG:style_emoticons/default/smile.gif)
Attached image(s) ![]() |
scott_in_nh |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States ![]() |
The splitter does a good job of distributing the heat to both sides of the car evenly, but I will agree with those who say duel fans are better, because to cfm is so low once split.
I'd like to know what fans you are using as the single factor fan seems bulky, doesn't put out a lot of cfm, and likely has a high amp draw. I was thinking about trying the blowers used for inboard boats.... |
Lo-Fi Version | Time is now: 25th June 2024 - 04:42 PM |
