> ^ conversion shift rod made with a steering universal joint, Who has done it and how well does it work?
bdstone914
post Jan 31 2017, 09:31 AM
bdstone914
I used to sell universal joints to THOMAS before he defected back to Germany which he used to made side shift trans rear conversion rods. I wonder who has done this and is there a noticeable improvement in shift feel?
I see the $200 shift couplers Pelican sells for 911's that are made with a similar principle.
http://www.pelicanparts.com/cgi-bin/ksearc...n=shift+coupler
Anyone use one of the above couplers and have an opinion to offer?
Rob-O
post Jan 31 2017, 10:01 AM
Clay Perrine...
He can give details. Maybe he'll see this and respond. Or you can PM him.
brant
post Jan 31 2017, 10:27 AM
the link didn't work for me
but I use a pair of universal joints, 360degree couplers on my custom shift linkage
I've got a few more tricks incorporated into mine too:
dual rear bushings on the console
a custom cup bearing holder
a custom shifter
and a straight chromoly rod
brass bushings on the rear
and a special delrin firewall bushing
its the best shifting 914 I've ever driven in 30+years of them.
jmill
post Jan 31 2017, 10:30 AM
Green Hornet
QUOTE(brant @ Jan 31 2017, 10:27 AM) *
a custom shifter
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
brant
post Jan 31 2017, 10:48 AM
here are some:
maf914
post Jan 31 2017, 11:01 AM
Not a Guru!
Tangerine Racing makes a linkage kit that uses what appear to be steering universal joints as well as dual bushings at the rear shift console.
http://www.tangerineracing.com/transmission.htm
JWest Engineering used to offer a linkage kit that included steering universal joints as well. I think that kit is discontinued.
I like the shift linkage that Brant has put together. Very neat. I need to learn to weld. (IMG:style_emoticons/default/welder.gif)
Universal joints, I think similar to the ones Brant used, can be found at Pegasus Racing.
https://www.pegasusautoracing.com/productse...sp?Product=1490
StratPlayer
post Jan 31 2017, 11:16 AM
StratPlayer
I just had the tangerine racing setup installed on my car. What a difference it makes.
Well worth the money.
brant
post Jan 31 2017, 11:22 AM
QUOTE(StratPlayer @ Jan 31 2017, 10:16 AM) *
NICE!
BIGKAT_83
post Jan 31 2017, 12:03 PM
I've done one with 2 universal joints on the shift rod and added another mount at the transaxle shift console. I also used a B&M mustang shifter. I removed all of this when I went to a Boxster transaxle.
Mark Henry
post Jan 31 2017, 12:35 PM
that's what I do!
I've done it with a steering coupler, I don't have the car on the hoist to take a pic.
To use them you have to have the twin bushing mod at the console.
Only bad on using the steering coupler is the joint is exposed, but if it's a fair weather car that shouldn't be an issue.
jmill
post Jan 31 2017, 12:41 PM
Green Hornet
Thanks Brant. That looks great. (IMG:style_emoticons/default/smilie_pokal.gif) I will most likely go a similar route.
post Jan 31 2017, 01:21 PM
914-6 GT in waiting
We use the Stompski couplers in all the 911's in the shop. Makes a huge difference. Stephen is s good friend of the shop and we have every tool and part he makes.
Olympic 914
post Jan 31 2017, 01:47 PM
QUOTE(Mark Henry @ Jan 31 2017, 01:35 PM) *
So the steering coupler won't fit inside that boot?
Mark Henry
post Jan 31 2017, 02:20 PM
that's what I do!
No, I imagine you could figure out something custom that works.
jmill
post Jan 31 2017, 04:00 PM
Green Hornet
I'm sure Stompski makes some great stuff but for the CSOB you can get something similar for @ $40.
http://www.mooreparts.com/steering-u-joints-quickners/
barefoot
post Jan 31 2017, 04:27 PM
Here's a selection for us CSOB types:
https://www.mcmaster.com/#universal-joints/=165m8jc
Mark Henry
post Jan 31 2017, 04:38 PM
that's what I do!
My linkage mod (IMG:style_emoticons/default/smile.gif)
porschetub
post Feb 1 2017, 02:28 AM
Mine was crap till I added front 2 way uni-joint,plan to add rear one also,talked to Chris but he won't sell the double bush console on its own so will fab my own one.
Mark Henry
post Feb 1 2017, 06:59 AM
that's what I do!
QUOTE(porschetub @ Feb 1 2017, 03:28 AM) *
I made my own bolt on double bush console as well, came out good, not a big deal but just for a boot solution I should have made the shaft about an inch longer at the U-joint.
The bolt on console is great for the bolt on crowd, but the next one for my sons 914 I'm just going to TIG weld heavy ears on like Brant has done.
- Lo-Fi Version Time is now: 19th April 2025 - 03:10 PM
