> 914World Classifieds Rules
> Rubber rain tray washers
Cal
post Feb 21 2017, 01:01 PM
Does anyone have the (2) rubber rain tray spacers / washers? I purchased a pair last year from a vendor on ebay but lost one while cleaning the plastic tray this winter. The ebay vendor doesn't carry them any longer.
euro911
post Feb 21 2017, 01:23 PM
I didn't know there were rubber spacers in there (IMG:style_emoticons/default/confused24.gif)
tweet
post Feb 21 2017, 01:36 PM
If you don't find one you can make a rubber spacer from some spare rubber hose, fuel line, air line, water line, etc. Just find the correct diameter and cut a slice off.
Mikey914
post Feb 21 2017, 02:25 PM
The rubber man
I suspect they are the same as the rocker panels? If so I will have shortly.
Cal
post Feb 21 2017, 07:13 PM
QUOTE(Mikey914 @ Feb 21 2017, 03:25 PM) *
Yes, they probably are the same size. I'll post a photo and the size of the one that I have.
Thanks
euro911
post Feb 21 2017, 07:49 PM
bdstone914
post Feb 21 2017, 09:48 PM
bdstone914
Never seen one on a tray. What would be the purpose of them?
Mikey914
post Feb 21 2017, 11:16 PM
The rubber man
These would allow for a lower angle of the tray in the back. I do believe that there were some on one I took apart, but not sure if it was that way from the factory. Seeing this and looking at the angle I suspect that it may be factory.
Firstcar
post Feb 24 2017, 10:27 AM
Obsessive amateur mechanic
FYI P/N 914.512.182.10 Not same part as rocker panel spacers according to PET. Two used only in rear. Part discontinued by Porsche.
Stoddard and Sierra Madre list reproductions on their sites.
Mikey914
post Feb 25 2017, 02:46 AM
The rubber man
Anyone have an OEM ?
914Next
post Feb 25 2017, 07:50 AM
QUOTE(Mikey914 @ Feb 25 2017, 03:46 AM) *
Mark, I haven't looked but I'm sure I have them on my car. Do you need them for reference? Would be glad to send as long as I would get them back. My car is in the shop for an oil change though so would not get to them until Monday or Tuesday.
Steve
Rob-O
post Feb 25 2017, 08:23 AM
I think the reason for them is to help space the away from the frame supports of the engine lid. If you look at this area carefully, if the spacer isn't there then the tray isn't supported under the fastener as you install the fastener. Tightening the fastener would lead to (most likely) a stress crack in the tray around that boss.
I didn't have the factory part, but went to the local ACE hardware store. They had plastic spacers/washers in different thicknesses. They're white plastic versus the black factory rubber, but they perform the same function as the factory part. I'll post a pic, this will help explain the supported/unsupported part...
Rob-O
post Feb 25 2017, 08:45 AM
This is the side closest to the battery. You can see that the rain tray has a step in this area. You can also see the captive nut that's welded onto the engine lid, and the support for the engine lid. My spacer is the white plastic piece in the photo.
Rob-O
post Feb 25 2017, 08:46 AM
The middle fastener should t need a spacer as there is no step in the rain tray and there is no engine lid support around the captive nut.
Rob-O
post Feb 25 2017, 08:53 AM
This is the drivers side. It has the rubber block that prevents an open trunk lid from impacting an open engine lid. That rubber arm has a square hole in it that if I remember correctly fits perfectly over the captive nut. I don't have the PET in front of me, but I remember looking at it before I tackled this project (powder coating the grills, adding the 'Porsche' lettering, adding the welting, the back edge protector, adding a rain tray and associated hardware). My car didn't have any of it but the poorly painted grills that were only fastened in one or two places. It rattled something fierce when the car was running!
Cal
post Feb 25 2017, 07:33 PM
Here's a photo of the original rubber washers from when I removed the rain tray to clean everything. The two anchor bolts that hold the washers are longer in length. The washers have lost their original shape.
Rob-O
post Feb 25 2017, 07:36 PM
QUOTE(Cal @ Feb 25 2017, 05:33 PM) *
Great point. I neglected to note that you need longer screws on the end pieces. I bought new screws and washers (stainless!) at ACE hardware too. My car was missing all of that! (IMG:style_emoticons/default/sad.gif)
- Lo-Fi Version Time is now: 24th November 2024 - 03:47 PM
