Early gear shift lever issue, Never seen this before?? |
mgphoto |
Mar 6 2017, 09:07 PM
"If there is a mistake it will find me" Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
So I'm getting ready to leave for the Phoenix club, start the car and I shake the gear lever, feels different, a bit loose, as I'm shaking it I notice it swivels, the shift lever rotates 360 degrees!
I Try shifting, it works as long as I shift according to the pattern, I can shift normaly but I have to be aware of the correct movement. Has this happen to anyone else? Any solution? Thanks Mike |
mepstein |
Mar 6 2017, 09:29 PM
914-6 GT in waiting Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If you need a replacement I can send you one ( the whole assembly) for the cost of shipping.
Cairo94507 |
Mar 6 2017, 09:42 PM
Michael Group: Members Posts: 9,858 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Typically the weld breaks and allows the shift lever spin. Happened to my Six. Just need to weld it at the base. (IMG:style_emoticons/default/welder.gif)
GeorgeRud |
Mar 6 2017, 10:07 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I seem to remember that the Weltmeister short shift kit used epoxy to attach the lever to it's base. If welding is not available for you, the epoxy would probably work for you as well.
jcd914 |
Mar 7 2017, 12:35 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I seem to remember that the Weltmeister short shift kit used epoxy to attach the lever to it's base. If welding is not available for you, the epoxy would probably work for you as well. I have re-epoxied several of the Weltmeister shift levers. I would pull them completely apart and clean the coupling and scuff it up with some emery cloth or fine sandpaper. Then I warm up the shift lever parts with a heat gun, so the epoxy thins out when applied. It means I can get it inside the joint. The epoxy set very fast when applied to warn metal parts so be quick. Jim |
rgalla9146 |
Mar 7 2017, 06:41 AM
Advanced Member Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Well this is great news.
I have a Weltmeister that has a very short lever. I can heat it, remove the original lever and either glue or weld a longer original in the short shift bottom. |
bdstone914 |
Mar 7 2017, 06:46 AM
bdstone914 Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
So I'm getting ready to leave for the Phoenix club, start the car and I shake the gear lever, feels different, a bit loose, as I'm shaking it I notice it swivels, the shift lever rotates 360 degrees! I Try shifting, it works as long as I shift according to the pattern, I can shift normaly but I have to be aware of the correct movement. Has this happen to anyone else? Any solution? Thanks Mike I have several early shifters too that are free. I am in Riverside. call me or text me a 951 536 7478 and I can have one in the mail tomorrow. Bruce |
rgalla9146 |
Mar 7 2017, 08:24 AM
Well this is great news. I have a Weltmeister that has a very short lever. I can heat it, remove the original lever and either glue or weld a longer original in the short shift bottom. Well...not so fast. The Weltmeister I have is welded. Beautiful TIG with original black paint top to bottom. |
mgphoto |
Mar 7 2017, 02:49 PM
Thanks mepstein and Bruce, I am going to take a look and see if I can weld it, if not I take a replacement. I'll let you know.
Thanks, Mike |
mgphoto |
Mar 7 2017, 04:19 PM
Lo-Fi Version | Time is now: 25th June 2024 - 05:10 PM |
