oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
76 2.0 FI stock except for Crane ignition. Car runs perfectly, all parts functioning, no vac leaks, idles at 6 to 700 fine. I was trying a possible fix for my engine "run on" after shutdown by adding a diode to the lead from the generator to the generator dash light. At the generator light in the dash, there is a blue wire to one side and on the other side is a short red/white stripe wire that goes immediately to the oil light. I installed the diode on the short red/white stripe wire between the generator light and the oil light. Did I stupidly put the diode on the wrong side of the generator light? Btw, I am taking the car in this AM for it's biannual smog check and I will have my mechanic check the timing before the smog check to rule that out as a possible cause of the "run on".
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,682 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
I was just wiring my dash yesterday and the diode in my wiring was in the Brown/White wire. Don't know about your year though, this is for a 73.
Attached image(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,999 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
That is a diode in the brake warning light circuit, not the charging system warning light circuit.
--DD |
Lo-Fi Version | Time is now: 24th June 2024 - 11:58 PM |
