Uni-body wha??, rigidity |
aveale |
May 4 2005, 01:24 PM
Fun Times Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 |
Family,
i am in the middle of a body make over (car). 1- where would people say is the area(s) that give the car most of its transverse (i.e. R/L) rigidity?? Thanx in advance. T |
Mueller |
May 4 2005, 01:33 PM
for side to side....
front bulkhead for gas tank(shock towers), firewalls (both) and the rear bulkhead between the shock towers....... |
aveale |
May 4 2005, 01:50 PM
What about the section that runs just in front of the seats?
The reason i ask is because i am doing the longs (because they are shot) and was wondering about side/side. thanx T |
Mueller |
May 4 2005, 02:03 PM
for a street car, yes, keep that section, if anything, it would help with a side impact.....on cars that get a full cage, that section is often removed.... |
freezing14 |
May 4 2005, 02:14 PM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
Hey Tony, long time no see,, i finally got mine on the road as of yesterday,, found out i have to adjust the shifter, the 4th and 5th wont go in at all, but otherwise it run ok ,, still have to tune the engine, got small issues, like the stumbling on acceleration, ( might be distributor), where are you at now,, have you doen your long already?? did you find any other suprise!!!!!
aveale |
May 4 2005, 02:52 PM
I wonder if anyone has done anything "different" under the car?
What about boxing in the longs from below, and that would also provide some nice jack points - makes sense in my mind. I am sure someone has done this before??? thanx. T ps freezing I emailed you and see you in Cobourg for the Canadian thing in August? |
Lo-Fi Version | Time is now: 25th June 2024 - 01:16 AM |
