db9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None ![]() ![]() |
I replaced the seal around the back of the roof several months ago. However, there is now a slight gap in the middle where the seal is about 1/8" off the targa, leading to wind and engine noise. I have tried putting the roof out in the sun, supporting the edges and then placing some weight in the middle along the back edge but it really hasn't seemed to help much.
Short of adding material under the rubber seal in the middle and tapering it to either side, are there other options I should try? I have checked with an early roof (the stock one) and a later model roof but no effect. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Curious, is the replacement the one with the fuzzey strip or without?
db9146 |
Mark,
Without. Dee |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Try adding a small piece of rubber tubing to each hook on the back. It's not on the hook but put the tubing on the rod that the hook grabs, it will pull it down a bit more.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,734 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I'd be curious if this is a factory seal, reproduction, or what's often called "OEM" which means it's supposed to be a factory supplier.
r_towle |
also, there seems to be early and late roofs.
The don't fit the same. Rich |
dgraves |
1974 914 2.0 ![]() ![]() Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains ![]() |
I replaced the seal around the back of the roof several months ago. However, there is now a slight gap in the middle where the seal is about 1/8" off the targa, leading to wind and engine noise. I have tried putting the roof out in the sun, supporting the edges and then placing some weight in the middle along the back edge but it really hasn't seemed to help much. Short of adding material under the rubber seal in the middle and tapering it to either side, are there other options I should try? I have checked with an early roof (the stock one) and a later model roof but no effect. I replaced my seal with one that has the fuzzy from 914Rubber. The fuzzy takes away all rubber squeak and seals air. I'm very happy with it. Dan |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I replaced the seal around the back of the roof several months ago. However, there is now a slight gap in the middle where the seal is about 1/8" off the targa, leading to wind and engine noise. I have tried putting the roof out in the sun, supporting the edges and then placing some weight in the middle along the back edge but it really hasn't seemed to help much. Short of adding material under the rubber seal in the middle and tapering it to either side, are there other options I should try? I have checked with an early roof (the stock one) and a later model roof but no effect. I replaced my seal with one that has the fuzzy from 914Rubber. The fuzzy takes away all rubber squeak and seals air. I'm very happy with it. Dan (IMG:style_emoticons/default/agree.gif) that's the one that Mark @914rubber recommended to me. |
Lo-Fi Version | Time is now: 25th June 2024 - 01:17 AM |
