Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Working on these right now as well as a few other goodies. But I noticed that some sway-bars look like there is a solid bushing. I'm sure these are stock as the drop link is conical to accept them. What are the variations on these???
901.343.783.00?? I have seen others list as one piece, but these are clearly 2. Attached image(s) ![]() |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,629 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Solid would likely be aftermarket. I can't say that is stock though....
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I am pretty sure that is not a 914 part. Chances are it was added to the car with an aftermarket or non-914 (say, a 911!) sway bar.
--DD |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
All factory stock 914 front swaybars I have seen have a solid rubber bushing, there is a small metal sleeve in it though. Look nothing like your picture.
![]() And the rears are nothing like that at all (IMG:style_emoticons/default/confused24.gif) |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
No way
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Mark,
That looks like the stock bushing in the picture that was installed by a goofball. It looks like it was cut in half and pressed in from both sides. The aftermarket poly bushings are made that way. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Those are Weltmeister bushings for front drop links. One of very few Weltmeister parts i use. Much easier to install. About $20 for a set of four.
Lo-Fi Version | Time is now: 25th June 2024 - 08:40 PM |
