GBallantine |
Member ![]() ![]() Group: Members Posts: 74 Joined: 12-October 04 From: Toronto,Ont.Canada Member No.: 2,930 ![]() |
Did a test and tune track day on Sat. with my new resto 2.0 /4 vintage race 914. The car ran strong except that it kept kicking off the alternator belt into the fan motor. Checked and replaced the belt, checked the alignment but same problem. Is there any type of belt tensioner available or is there a simpler fix.
GB |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,713 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
the alternator itself is the belt tensioner. losen the nut for the alternator and pry it towards the drivers side (with the belt on) until the tension of the belt is good, then re-torque the bolt ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
And if you haven't....check for a broken mount (upper tensioner). It's a piece of thin metal and breaks...uh huh, uh huh......
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
If its a track car why run the alt?
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Joe |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,002 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Some suggestions--
Try using the "solid" belts, rather than the ones with "teeth". Try some "belt dressing" on them--that may help them to slide along inside the pulleys rather than popping out. Try not to hit the rev-limiter. Re-check the alignment of the alternator pulley and fan pulley. I know you checked it, but this was what finally worked out for me. I just f--ed with the alternator lower bracket a bunch of times (PITA!) and then the thing stopped throwing belts. --DD |
KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
I had trouble when I used a "Auto Store" replacment.
Fixed the problem by using an OEM replacment from Peilican. There is a slight difference in size from between a "after-market" belt and an OEM belt. Ken |
Lo-Fi Version | Time is now: 2nd July 2024 - 04:50 AM |
