rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,727 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Big day for my GT project.
Getting a combination soda blast and garnet blast on my bare chassis and all the removable panels. The baking soda is used to remove paint and is suitable for the body panels. The garnet is much more course and removes surface rust on the undersides. I hope I did enough to keep it out of the longs and all the other cavities. Fingers crossed. Attached image(s) ![]() |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,525 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Big day for my GT project. Getting a combination soda blast and garnet blast on my bare chassis and all the removable panels. The baking soda is used to remove paint and is suitable for the body panels. The garnet is much more course and removes surface rust on the undersides. I hope I did enough to keep it out of the longs and all the other cavities. Fingers crossed. Awesome .. I want to do that in just spots on my car once the welding is all done. |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,879 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Is that you doing the blasting? You might not be able to keep out every bit of dust, but with a bit of effort you can get most of it. The sound of the engine will drown out anything that is rattling around in the longs anyways
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,809 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Your neighbors are going to love you.
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,717 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
congratulations she is looking good!
porbmw |
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None ![]() ![]() |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,799 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Very cool! Do the best you can to blow and vacuum it out. Then move on.
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
Great job, one step at a time.
rgalla9146 |
Is that you doing the blasting? You might not be able to keep out every bit of dust, but with a bit of effort you can get most of it. The sound of the engine will drown out anything that is rattling around in the longs anyways Not me, I took the pic. Two guys doing one hour stints each. All day. Soda on the outside bodywork and garnet on the bottom. The noise was friggin' LOUD I specified a weekday so most of my neighbors were out. I would have dipped and E coated but the longs were already reinforced. I used duct tape, dum dum, butyl and hardware to fill every hole along the longs the rollbar, the windshield frame and all crossmembers. I'v only done preliminary blow and vacuum cleaning so far. The ability to roll the car over easily is key to removal of contamination. I added a picture of removal of the Karmann tag. I levered the rivets out from behind. Attached image(s) ![]() ![]() |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,406 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
Looking good there Rory.
How did the chassis look after the blasting ? I know there wasn't too much rust when I had it. |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,268 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
(IMG:style_emoticons/default/beerchug.gif) That is definitely the way to begin one of these builds. I love the removal of the Karman tag too. Now we need to see how it came out after blasting please.
rgalla9146 |
Looking good there Rory. How did the chassis look after the blasting ? I know there wasn't too much rust when I had it. Hey Luke No big surprises. I had to replace the drivers door.... it was already painted and buttered up twice. I decided not to replace the rear of the floor. The issues it had were cosmetic.....dents and some welding. I put the jack receivers back on and replaced the pass. rear ear. along with some additional reinforcements on the both rear ears. The chassis is solid. Next it goes to get primed and initial body work. |
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
Only way to go ...............
That way you know what you have from the get go. |
ValcoOscar |
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,493 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California ![]() ![]() ![]() |
Great job....nice that you are taking proper safety precautions with that hood. Looks like an Apollo 600 set up.
I am lucky enough to have a sandblast room here at work. I can help any SoCal MEMBERS with blast projects, if anyone is interested. I will donate room and media....operator labor is minimal. Keep up the good work an keep us posted on progress. (IMG:style_emoticons/default/aktion035.gif) |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,299 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Go Rory Go!
rgalla9146 |
My chassis was blasted about a month ago.
I finally got a long time friend to come to do the prep/prime and hammer/dolly work. I'm hoping to get to a paint booth in a month. Attached image(s) ![]() ![]() ![]() |
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,542 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
Looks great! Do tell about that trans support "cover". I've been working up a design for stiffening mine and yours caught my eye.
Details man, I want some details! |
Krieger |
That is going to look great! What color are you going to paint it?
rgalla9146 |
Looks great! Do tell about that trans support "cover". I've been working up a design for stiffening mine and yours caught my eye. Details man, I want some details! It's 18 ga. fabed at a local metal shop . 48" wide then whittled down to contact the outside ends of the original crossmember. 2 1/8" deep x 3 1/8" wide. I'll include the nut to secure the spare tire and a couple pads for the tire to rest on as well. I not a fan of the tubular diagonal supports. |
rgalla9146 |
Lo-Fi Version | Time is now: 2nd April 2025 - 06:35 PM |
