EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Was driving last week and the generator light came on, went off, came on again, and then it stayed on.
Belt is on, VR was swapped with another I have around (and another is on the way), ground at the tranny is connected and good, battery charged and tightened, fuses 8 & 9 are good and new, spun to make sure they are connected. Voltage meter is showing 12 to 13. Anything else I can troubleshoot before I pull the generator? (IMG:style_emoticons/default/dry.gif) |
EdwardBlume |
And its running fine.....
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 592 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
Check the voltage at the battery using a DVOM. Should be about 12-12.5V with the car off and about 13.5-14.2 with the car running.
If the voltage is low with the car running, then either the regulator or the alternator are bad. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Check the voltage at the battery with the engine running. It should be 14+ volts. It looks like you have eliminated most everything but that.
EdwardBlume |
Thanks guys. The battery is coming through at 12.2 off and running at idle 13.65. Does that mean it's charging?
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,779 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
IF the voltage is higher when running you have charge,do a load test,lights on ,stereo on,fan blower on max.................... this will tell you whats really happening,don't trust the amps gauge,put your meter directly on the battery,good luck.
EdwardBlume |
IF the voltage is higher when running you have charge,do a load test,lights on ,stereo on,fan blower on max.................... this will tell you whats really happening,don't trust the amps gauge,put your meter directly on the battery,good luck. With the lights on and wipers going (no radio currently) at idle, I'm getting 11.8 on the battery. |
Elliot Cannon |
IF the voltage is higher when running you have charge,do a load test,lights on ,stereo on,fan blower on max.................... this will tell you whats really happening,don't trust the amps gauge,put your meter directly on the battery,good luck. With the lights on and wipers going (no radio currently) at idle, I'm getting 11.8 on the battery. What does it read when you rev the engine above idle? |
EdwardBlume |
New alternator, battery, and voltage regulator. Still on... (IMG:style_emoticons/default/headbang.gif)
porschetub |
New alternator, battery, and voltage regulator. Still on... (IMG:style_emoticons/default/headbang.gif) Darn got a similar mystery tried 3 VR's,until I pull my altenator I don't know,in a six bit of a mission,charge is just above battery when running but not a lot ,been rebuilt ???????. |
Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
You don't have an LED in the gauge do you?
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,795 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Test the wire after the vr back to the light. Is this the wire that has a resistor in it near the gauge?
EdwardBlume |
EdwardBlume |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,235 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Good used (tested) or new on the alt change?
EdwardBlume |
EdwardBlume |
Here's the one I pulled. Looks like the boot melted. Is this normal? Or a sign of failure?
Attached thumbnail(s) ![]() |
rhodyguy |
Are there arching marks on the inside face of the rear cover?
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,459 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Here's the one I pulled. Looks like the boot melted. Is this normal? Or a sign of failure? A melted boot, thus heat, may be a sign of increased resistance from a bad connection. It's possible the large wire connection there was rusty or not very good. I'd clean all that up, ensure a nice clean connection, ensure a good solid wire ring end, use some dieletric grease and see how well it works. |
914Tom |
Member ![]() ![]() Group: Members Posts: 122 Joined: 11-February 07 From: Germany Member No.: 7,526 ![]() |
only my 2c. If Voltage is correct an it is so. Alternator, Battrey and Voltage Reg. is OK.
There can only be a whiring, maybe ground, issue with the Light. |
Lo-Fi Version | Time is now: 12th March 2025 - 04:58 AM |
