Speedo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,554 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
You need to specify what size air horns ( or velocity stacks ) and for which carbs. Doubt you are going to find someone who has what you need and wants a CAT bypass.
Speedo |
Looking to put this in the hands (or engine compartment) of someone that can use it.
I run weber 40 triples. If someone has air-horns/velocity stacks that are extra to what they need...and can use this, let me know. Will trade for anything 914 actually...except engine parts. I have enough engine parts. You need to specify what size air horns ( or velocity stacks ) and for which carbs. Doubt you are going to find someone who has what you need and wants a CAT bypass. |
bdstone914 |
Looking to put this in the hands (or engine compartment) of someone that can use it. I run weber 40 triples. If someone has air-horns/velocity stacks that are extra to what they need...and can use this, let me know. Will trade for anything 914 actually...except engine parts. I have enough engine parts. You need to specify what size air horns ( or velocity stacks ) and for which carbs. Doubt you are going to find someone who has what you need and wants a CAT bypass. Thanks for clarifying what you are looking for. From what I can see new stacks are about $50 each. The cat bypass pipe is $36 new. Just saying... |
Lo-Fi Version | Time is now: 27th June 2024 - 08:35 PM |
