Plastic Inner Long Plugs, Does anybody report these? |
amfab |
Jun 12 2017, 07:28 PM
Member Group: Members Posts: 401 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Does anyone make reproductions of the oval plastic plugs for the inner longs?
TIA -Andrew |
Jett |
Jun 12 2017, 09:01 PM
Senior Member Group: Members Posts: 1,675 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I need some as well...
914Rubber? Mark can you build these? |
IronHillRestorations |
Jun 13 2017, 05:50 AM
I. I. R. C. Group: Members Posts: 6,795 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
They are a tar mat, not plastic
amfab |
Jun 13 2017, 12:15 PM
Jun 13 2017, 12:23 PM
mbseto |
Jun 13 2017, 12:41 PM
Senior Member Group: Members Posts: 1,257 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Cut one out of a shingle? Not really a recommendation, but when I pulled mine off I remember thinking, man, that's just like a piece of shingle.
Mikey914 |
Jun 13 2017, 01:50 PM
The rubber man Group: Members Posts: 12,742 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Shoot me a pic. We can mass produce these pretty inexpensively.
gcrotvik |
Jun 13 2017, 02:01 PM
Member Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Shoot me a pic. We can mass produce these pretty inexpensively. Mark, I have one. I will drop it by your shop. I could use a few sets myself. If I could make a suggestion/recommendation on these. I believe they are 3MM thick but the actual inset in the long is about 5MM deep. If you could find the correct thickness of material that would be great. That way the surface of the plug is level with the outer surface of the long. Greg |
amfab |
Jun 13 2017, 02:11 PM
Shoot me a pic. We can mass produce these pretty inexpensively. Mark, I have one. I will drop it by your shop. I could use a few sets myself. If I could make a suggestion/recommendation on these. I believe they are 3MM thick but the actual inset in the long is about 5MM deep. If you could find the correct thickness of material that would be great. That way the surface of the plug is level with the outer surface of the long. Greg Great! This place is awesome BTW |
Mikey914 |
Jun 13 2017, 02:16 PM
Thanks that would be great, I know the part now. Had to think about it. Pretty sure we can do something that will be equivalent to OEM.
Mark |
914werke |
Jun 13 2017, 09:12 PM
"I got blisters on me fingers" Group: Members Posts: 11,050 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I made some of these, not sure but I may have a set or two left over.
They are a OE Porsche material even (IMG:style_emoticons/default/smile.gif) I took the sound deadening pad from behind the back pad made an oval punch the correct size and cut them from the flat section of the pad. Could have been the same material originally. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 15th January 2025 - 03:14 AM |
