Oil Cooler, Time to Replace? |
Porscheguy912 |
Jun 15 2017, 06:36 AM
porscheguy912 Group: Members Posts: 46 Joined: 10-April 14 From: Summit, NJ Member No.: 17,236 Region Association: North East States |
McMark |
Jun 15 2017, 07:09 AM
Just because? No.
Is it running hot? Drop the motor, pull the top tins off the motor and clean 43 years of crud/leaves/etc off the fins and oil cooler. And if you really wanna go all in, ditch the single center carb and go with stock FI or dual IDF/HPMX/DRLA carbs. |
bdstone914 |
Jun 15 2017, 07:57 AM
bdstone914 Group: Members Posts: 4,744 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Just because? No. Is it running hot? Drop the motor, pull the top tins off the motor and clean 43 years of crud/leaves/etc off the fins and oil cooler. And if you really wanna go all in, ditch the single center carb and go with stock FI or dual IDF/HPMX/DRLA carbs. (IMG:style_emoticons/default/agree.gif) Do you know it is running hot? Do you have an oil temp gauge ? I had a 1.8 that was running hot. Added an external cooler which brought down the temps. When the engine failed due to stripped teeth on the cam gear I found the original cooler was on the top with oil sludge. Only fix it if it is broken. |
Lo-Fi Version | Time is now: 15th January 2025 - 05:22 AM |
