Windshield install with butyl - is butyl primer needed? |
Kansas 914 |
Jun 23 2017, 07:41 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I have brand new paint on the car. I remember the last time I had a windshield installed by I don't think the installer used primer.
Is it best to prime the frame first and is butyl primer the right stuff? Like this? https://www.amazon.com/CRL-Pinchweld-Primer...uct_top?ie=UTF8 |
76-914 |
Jun 23 2017, 07:48 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I did not use any however I did prep with Lacquer Thinner to remove any grease/oils. (IMG:style_emoticons/default/beerchug.gif)
Mark Henry |
Jun 23 2017, 08:00 AM
What size is the correct butyl...it's the tape right?
And is it the same for the rear window? I have to reseal my rear window, looks like a rubber seal, but that's just butyl tape gone hard , I'm I correct on this? |
mepstein |
Jun 23 2017, 08:07 AM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mark Henry |
Jun 23 2017, 08:09 AM
What size is the correct butyl...it's the tape right? And is it the same for the rear window? I have to reseal my rear window, looks like a rubber seal, but that's just butyl tape gone hard , I'm I correct on this? Yes, butyl tape on the rear Thanks Mark...another job for the list. |
Kansas 914 |
Jun 23 2017, 08:11 AM
What size is the correct butyl...it's the tape right? And is it the same for the rear window? I have to reseal my rear window, looks like a rubber seal, but that's just butyl tape gone hard , I'm I correct on this? Yes, butyl tape on the rear I used 5/16" 3M Windo-Weld available from Amazon. https://www.amazon.com/gp/product/B000CQ4AO...=UTF8&psc=1 5/16" (8mm) is correct for the front as you need to make sure the "chrome" trim snaps into place. I have heard horror stories about using 3/8". The manual says 5/16" (8mm) for rear glass as well but it is not as critical since there is no trim. |
Dave_Darling |
Jun 23 2017, 09:24 AM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Using the primer is not necessary, but it does help the butyl to grab better.
--DD |
IronHillRestorations |
Jun 23 2017, 09:35 AM
I. I. R. C. Group: Members Posts: 6,792 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Butyl primer will improve the seal. For $17 more, why wouldn't you use it?
Kansas 914 |
Jun 23 2017, 10:45 AM
Mikey914 |
Jun 23 2017, 02:39 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
no primer required
New paint not needed for sure. In stock Have a set of instructions on site http://shop.914rubber.com/Butyl-Cord-95mm-...m?categoryId=-1 Rear glass kit with setting blocks http://shop.914rubber.com/rear-window-rese...m?categoryId=-1 |
bbrock |
Jun 23 2017, 05:58 PM
With luck, I'll be facing this task in the not too distant future. Other than originality, are there reasons to stick with butyl instead of moving to a modern urethane seal? (IMG:style_emoticons/default/confused24.gif)
Jun 23 2017, 09:10 PM
Butyl tape is a consistent thickness, in this case 5/16", which is required to get the windshield trim to attach properly.
I haven't installed a windshield in over 10 years, but I think the urethane doesn't come in a cord or tape, it's in a tube. What I like about the primer, in addition to the fact that the butyl adheres and seals to it better, is it "paints" the windshield recess black, so you don't have edges of Saturn Yellow, or Marathon Blue (or whatever color your 914 is) peeking out from around the windshield perimeter |
Montreal914 |
Jun 23 2017, 09:45 PM
Senior Member Group: Members Posts: 1,725 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
For the rear window, I have used 5/16 butyl about 6 years ago. No issues. I had removed all traces of the original adhesive and degreased the paint with alcool. Nice fresh surface.
You want to use electric tape on the lower cabin side of the window to hide the butyl. While in there, I remember replacing the rubber lip (914 rubber) that reach over the engine lid Good luck. |
Dave_Darling |
Jun 23 2017, 10:07 PM
Other than originality, are there reasons to stick with butyl instead of moving to a modern urethane seal? (IMG:style_emoticons/default/confused24.gif) I have heard reports that the urethane does not give as much as the butyl does, and windshields tend to crack more easily when installed in our flexy fliers with urethane than with butyl. No experience myself, but I used butyl on my car and it is holding up well. --DD |
bbrock |
Jun 23 2017, 10:49 PM
Other than originality, are there reasons to stick with butyl instead of moving to a modern urethane seal? (IMG:style_emoticons/default/confused24.gif) I have heard reports that the urethane does not give as much as the butyl does, and windshields tend to crack more easily when installed in our flexy fliers with urethane than with butyl. No experience myself, but I used butyl on my car and it is holding up well. --DD Makes sense. I've installed two 914 windshields many years ago and the butyl also seems like it would be easier, but no direct experience with urethane. Just wondered if there was any advantage. I like the idea of sticking with what's familiar. BTW, on the two windshields I did, one was done with and the other without primer. I definitely preferred the primered install for all the reasons already mentioned (better stick, and leaves a nice black welt). |
stevegm |
Feb 11 2020, 07:22 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
914rubber’s kit is 9.5 mm, which is 3/8”.
I have also heard 5/16” is correct, which is 7.94 mm. Does anybody know which is correct? I want to use stock windshield trim. Has xx anyone used either size with chrome? |
914werke |
Feb 11 2020, 08:18 PM
"I got blisters on me fingers" Group: Members Posts: 11,030 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Other than originality, are there reasons to stick with butyl instead of moving to a modern urethane seal? (IMG:style_emoticons/default/confused24.gif) I have heard reports that the urethane does not give as much as the butyl does, and windshields tend to crack more easily when installed in our flexy fliers with urethane than with butyl. No experience myself, but I used butyl on my car and it is holding up well. --DD I can attest that is the case... (IMG:style_emoticons/default/sad.gif) Fortunately this is a DIY job, Helps to have a buddy cuz you have one shot to stick it in the correct position. On windshields youd be hard pressed nowadays to find a shop that will put one in with Butyl |
ConeDodger |
Feb 11 2020, 08:30 PM
Apex killer! Group: Members Posts: 23,853 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I did this alone but another set of hands would be good. I used butyl and primer. Didn’t cost that much more to do it right. I’ve been around here long enough to hear a few horror stories about cracked windshields because of the modern goop. The shops were even claiming butyl wasn’t legal in California anymore. Not true.
#1 thing to do “while you’re in there” so to speak. Replace the forward vinyl behind the dash. Given the 914rubber.com dash board quality, you should do that too... |
lierofox |
Feb 11 2020, 08:32 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
https://www.amazon.com/gp/product/B00473W5V...=UTF8&psc=1
I used this stuff to primer my windshield and frame. Buddy of mine was the son of an auto glass guy so he helped with installing dozens of them over the years. Primer every time or it'll eventually begin to leak. I think he mentioned that it also helps provide a bit of extra protection to the butyl since it helps to mask the sunlight, in addition to the glass blocking the UV. From what I understand, modern urethane adhesives, when they grab on, hold on WAY too well and the windshield becomes a structural/shear member of the car, and all the flex ends up being transferred into the windshield glass, which the 914 windshields were never designed to be used for, causing them to crack. |
bbrock |
Feb 11 2020, 08:55 PM
914rubber’s kit is 9.5 mm, which is 3/8”. I have also heard 5/16” is correct, which is 7.94 mm. Does anybody know which is correct? I want to use stock windshield trim. Has xx anyone used either size with chrome? The factory manual specs 8mm butyl for both front and rear glass. Despite having a fresh 3/8" 914Rubber kit on hand, I bought 5/16" rope for the rear and it worked perfectly. I will use the same when I do the windshield. |
Lo-Fi Version | Time is now: 27th December 2024 - 03:42 AM |
