rad23racer |
Newbie ![]() Group: Members Posts: 17 Joined: 28-May 17 From: Corona, CA Member No.: 21,137 Region Association: Southern California ![]() |
I'm trying to remove the shift rod from the linkage on the transmission so I can replace the bushing that is destroyed. I pulled the tapered screw out but this thing doesn't want to budge. Before I get creative, I thought I would check and see if there is a trick to getting the rod out.
Thanks... |
bretth |
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region ![]() |
I'm trying to remove the shift rod from the linkage on the transmission so I can replace the bushing that is destroyed. I pulled the tapered screw out but this thing doesn't want to budge. Before I get creative, I thought I would check and see if there is a trick to getting the rod out. Thanks... On mine I just shifted between 2nd and 3rd a couple times and it just came off. Maybe you need to hold back on the shaft while someone pulls the shifter back. Remember not to reuse the screw because they can come loose. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Another option for the cone head screw is to us a standard square head VW Beetle shift rod screw.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Twist the shift rod at the coupler to break the tension. put the shifter in 2nd or 4th. with one person at the shifter get under the car and open up an adjustable wrench to slide onto the exposed part of the front shift rod. have the person inside pul the shifter back to break loose the coupler from the front rod. might take a couple of smacks.
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
I used one like this.
rad23racer |
I used one like this. ![]() Sometimes I just feel like a moron. The puller should work nicely. I forgot to mention that the transmission and shift rod are out of the car sitting on the workbench so I have easy access to them. Thanks everyone for your help. I'll let you know how it goes. |
rstover |
Member ![]() ![]() Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region ![]() |
Make sure the screw is out far enough. It has to be nearly all the way out.
Lo-Fi Version | Time is now: 20th June 2024 - 06:02 AM |
