Subaru 2wd blanking plate drawing |
nick1973 |
Jul 10 2017, 06:38 AM
Newbie Group: Members Posts: 6 Joined: 29-April 15 From: Doncaster in the sunny uk Member No.: 18,678 Region Association: None |
Hello has anyone got a drawing of the blanking plate for the trans I want to get one laser cut is not ill start drawing one up
thanks nick |
76-914 |
Jul 10 2017, 08:55 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Just use the rear cover as a template and drill guide. (IMG:style_emoticons/default/beerchug.gif)
Keyser Sose |
Jul 10 2017, 08:58 AM
Member Group: Members Posts: 57 Joined: 1-July 14 From: West Member No.: 17,576 Region Association: None |
That's what I did, that or a gasket. Then cut it out with a jigsaw and drilled it with a hand drill, cleaned it up with a file. Twenty minutes, easy.
If you do get one laser cut you should see what it costs to make several extras at the same time. The major cost is in machine setup, so the additional plates should be little more than the cost of the additional material. Sell the extras to pay for yours, and your fellow swappers will thank you. |
mepstein |
Jul 10 2017, 09:57 AM
914-6 GT in waiting Group: Members Posts: 19,515 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
That's what I did, that or a gasket. Then cut it out with a jigsaw and drilled it with a hand drill, cleaned it up with a file. Twenty minutes, easy. If you do get one laser cut you should see what it costs to make several extras at the same time. The major cost is in machine setup, so the additional plates should be little more than the cost of the additional material. Sell the extras to pay for yours, and your fellow swappers will thank you. Ross / Rnellums altrady does this |
rnellums |
Jul 10 2017, 09:59 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I have a few of these left from a run I did a while ago. I was asking 40$ for them, laser cut from aluminum. Not sure if shipping to UK would be cost prohibitive though!
-Ross |
JRust |
Jul 10 2017, 03:26 PM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I have a few of these left from a run I did a while ago. I was asking 40$ for them, laser cut from aluminum. Not sure if shipping to UK would be cost prohibitive though! -Ross I have one of Ross setup's. Good setup at a great price. I doubt shipping would be to bad for it. I have seen other guys just cut some diamond plate if it is. Pretty simple with the rear diff cone for a template. |
Lo-Fi Version | Time is now: 26th September 2024 - 11:55 AM |
