jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I'm installing the new 914Rubber HID headlights; new to know whether the plastic cover/shell over the front of the HID is supposed to stay or be removed
1st pic shows that cover partially off 2nd pic is the cover on and the end-thingy screwed in... Attached image(s) ![]() ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The cover stays on. It actually helps make them waterproof. There is also a second set included.
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,350 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
It's not HID, it's LED. Completely different tech.
Mikey914 |
jim_hoyland |
The cover stays on. It actually helps make them waterproof. There is also a second set included. Thanks ! And I found the second set, kinda hard to see if I didn't know they were packed in the foam..... Attached image(s) ![]() |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
The cover stays on. It actually helps make them waterproof. There is also a second set included. Silly Mark. You do know that neither Jim's or my car have ever been out in the rain right? (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) |
jim_hoyland |
All done....great kit !
ConeDodger |
Nice! (IMG:style_emoticons/default/evilgrin.gif)
Mikey914 |
Yes we kissed a lot of frogs to find these.
GB expires soon. |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
The cover stays on. It actually helps make them waterproof. There is also a second set included. Thanks ! And I found the second set, kinda hard to see if I didn't know they were packed in the foam..... interesting- i did not have this in my packaging- no second set (IMG:style_emoticons/default/confused24.gif) |
Mikey914 |
The cover stays on. It actually helps make them waterproof. There is also a second set included. Thanks ! And I found the second set, kinda hard to see if I didn't know they were packed in the foam..... interesting- i did not have this in my packaging- no second set (IMG:style_emoticons/default/confused24.gif) Not all have them. I know I put an extra set in with his as I didn't need them. |
jim_hoyland |
how do we know when the 2nd set is needed ? Do the original have a wear factor ?
Mikey914 |
No wear on this part. They were some extra coated lenses we got and rather than having them sit around on the shelf or get broken I asked Topher to ship them out with orders as he got them out the door. A unannounced bonus.
Lo-Fi Version | Time is now: 26th June 2024 - 07:50 AM |
