Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,170 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
You know the old adage, never say how great your car is running lest the Air cooled gods decide to wheel in and smite thee...
So I took the car out today, beautiful early September day, with my daughter, to look at a car for her. When I got home, I noticed a trail of drips in the driveway. Hmmmm... So after cleaning up underneath, my wife started it while I hoped to see from where it was leaking. Suddenly, here it comes, right down what appears to be the case, between the oil filter and the pushrod. Oil cooler seal? Wait, could it be the pressure sender? I gotta go see. (IMG:style_emoticons/default/unsure.gif) Anyways, here's a pic. Any input appreciated... ![]() |
Porschef |
Ok. Nevemind.
Yes, it was the sender unit plumbing that failed. I went out and before I could disconnect the wires, I could see there was too much movement... An easy fix. I guess I should use galvanized nipples instead of brass... Thankfully it didn't happen whilst tooling back from Mort's with some ' Dan blasting.,, (IMG:style_emoticons/default/aktion035.gif) |
Porschef |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
Engineering fail (IMG:style_emoticons/default/shades.gif) Vibration and the weight of the sender is what cracked the pipe. Use a stronger pipe and the case threads may see the effects of vibration. A sender like that is better mounted to the engine with a flex hose in between. |
bretth |
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region ![]() |
Last time I had my home oil heater serviced we had a leak in one of the threaded oil pipe connections. The tech told me that a previous tech should not have used Teflon tape as it will be dissolved by the oil. I assume he used pipe dope instead. Has the Teflon on your connections been holding up OK?
Brett |
Porschef |
Ed, Brett, thanks. Ed, I thought my arrangement was solid enough, without contact with anything but the air seal grommet. But I guess after x amount of times putting my foot in it, it gave up.
Oh well, back to the drawing board. I'll see if I can find a substitute, otherwise I will just repeat and keep my eye on it. Thanks for all the advice. Brett, I'll try some thread sealer. Maybe some of my prior leaking was due to the Teflon tape. |
jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
Ed, Brett, thanks. Ed, I thought my arrangement was solid enough, without contact with anything but the air seal grommet. But I guess after x amount of times putting my foot in it, it gave up. Oh well, back to the drawing board. I'll see if I can find a substitute, otherwise I will just repeat and keep my eye on it. Thanks for all the advice. Brett, I'll try some thread sealer. Maybe some of my prior leaking was due to the Teflon tape. Brass will crack under vibration over time. Get yourself a greasegun hose. Mount a block type fitting (brass ok here, its massive) with three holes. Figure out how to mount it all on the OUTSIDE of the engine tin. |
jeffdon |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Absolutely--a flex hose is needed, the pipe and sender act as a pendulum. You're lucky that it was the pipe that failed, and not the case.
--DD |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
Glad it wasn't something major...or that you didn't dump all your oil.
Joe...highly recommend this kit. Beautifully done. The block will accommodate both senders and even has a spare port for an NPT pressure gauge. Great setup. http://www.42draftdesigns.com/vw-audi-oil-...relocation-kit/ |
Porschef |
Gentlemen, thanks to all who've replied. I never even considered that the case threads might be damaged. Fortunately, when I removed the fitting from the case at the breakpoint, there was no apparent damage.
I shall do as suggested, and get myself a grease gun hose. Now I understand why they're used. Ian, that's a sweet looking kit. However, my inner Rube Goldberg is telling me I can make it happen with a GG hose, a clamp or two, and some IPA cipherin'... (IMG:style_emoticons/default/wacko.gif) Stay tuned |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
When using the grease gun whip remember the sensor has to be grounded.
So you need to use a steel or aluminum strap on the sensor body and screw/bolt it to a good ground. |
Porschef |
Cool, thanks Mark. Picked up a gun hose this morning. Just getting ready to get going on it. Hopefully back on the road in a couple hours... (IMG:style_emoticons/default/smile.gif)
11tenths |
Ve get too soon old, und too late schmart ![]() ![]() Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States ![]() ![]() |
IPA?? Factory fill calls for Hofbräu on that repair.
(IMG:style_emoticons/default/beerchug.gif) -Harry |
Porschef |
You're right Harry. This should get me through the job...
![]() Thanks for the tip (IMG:style_emoticons/default/beer.gif) |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
(IMG:style_emoticons/default/laugh.gif) Hey! Warsteiner is my standard beer. Cheers.
Porschef |
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
Hope you're safe Mike |
Porschef |
Ok, done, despite many interruptions.
Nothing beautiful to see here, strictly function. I do notice that the gauge has a slight delay in reading, maybe there's air in the line, I don't know, but eventually will read out what it did prior to the hose installation, even if it is only a fraction of a second longer. Thanks to all who replied and helped me get the job done ![]() |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Grease gun hose is a bad choice btw.
They can't take the oil temp. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Last time I had my home oil heater serviced we had a leak in one of the threaded oil pipe connections. The tech told me that a previous tech should not have used Teflon tape as it will be dissolved by the oil. I assume he used pipe dope instead. Has the Teflon on your connections been holding up OK? Brett NEVER heard of teflon tape being dissolved by oil. used in test rigs for Jet A aircraft kerosene for many years with no issues. Not much will dissolve teflon. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:24 AM |
