holes in longs, how to mend these? |
914 RZ-1 |
Sep 9 2017, 06:05 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I took off my rocker panels and found a huge pile of dirt around the jack hole. After cleaning it, I found 4 small holes in the driver's side.
How should these be patched: weld a rectangular piece over the hole (or all 4 of them) OR weld a piece flush in each hole? Or does it even matter? I will have to take it to a place, so I'm assuming I can drive the car without rocker panels, correct? |
rhodyguy |
Sep 9 2017, 06:16 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Take off the loose material to the right of the holes.
PlantMan |
Sep 9 2017, 06:18 PM
Member Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
I took off my rocker panels and found a huge pile of dirt around the jack hole. After cleaning it, I found 4 small holes in the driver's side. How should these be patched: weld a rectangular piece over the hole (or all 4 of them) OR weld a piece flush in each hole? Or does it even matter? I will have to take it to a place, so I'm assuming I can drive the car without rocker panels, correct? Those are very interesting holes..... It almost looks like someone did some previous patch work on that long....What does the other side look like? I would poke around that area with a screw driver for any soft spots. Usually there is a weep hole on the bottom of the jack post plate. I am not seeing that in this pic. |
914 RZ-1 |
Sep 9 2017, 06:22 PM
914 RZ-1 |
Sep 9 2017, 06:27 PM
It almost looks like someone did some previous patch work on that long....What does the other side look like? I would poke around that area with a screw driver for any soft spots. Usually there is a weep hole on the bottom of the jack post plate. I am not seeing that in this pic. The other side is fine. I think the car was in a wreck and repaired: the driver's side fender is a from a later model year, there is no jacking donut on the driver's side, the pan is dented, but banged out, the tube for the trunk cable was all bent, and the car was painted white, though it was originally silver. Everything is straight and it looks like a decent job. However, I'm finding evidence of repairs as I take the car apart and fix stuff. |
PlantMan |
Sep 9 2017, 06:32 PM
If it was in an accident that would explain a few things.
Chris914n6 |
Jackstands are my life. Group: Members Posts: 3,423 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Not a normal place for factory undercoating. I'd scrape it off to get a better look, might be hiding more rust/other issues.
Also not a place for weld beads to be. Looks to be repaired, questionably.... |
SirAndy |
Sep 10 2017, 07:34 PM
Resident German Group: Admin Posts: 41,943 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Looks to be repaired, questionably.... (IMG:style_emoticons/default/agree.gif) I'm guessing those holes were part of pulling the car back into shape ... (IMG:style_emoticons/default/idea.gif) |
Andyrew |
Sep 10 2017, 07:41 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I would start wire wheeling that area and the area under it and start poking hard. Cutout affected areas and replace with good steel. That does not actually look that bad, the jack post looks solid.
I think a decent metal guy could fix it in a weekend.. |
Mblizzard |
Sep 11 2017, 10:51 AM
I have a similar poor repair that is not rusted but certainly substandard.
I will be verifying there is not reaming rust and add Restoration Designs Frame stiffener overlay. http://www.restoration-design.com/store/product/PP346L |
914 RZ-1 |
Sep 16 2017, 01:07 PM
live free & drive |
Sep 16 2017, 01:28 PM
Member Group: Members Posts: 181 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
Maybe your car was treated for rust by Zeibart - they drilled holes to get the wands in.
Does it have the same holes on the other side? |
injunmort |
Sep 16 2017, 06:38 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
fwiw, i would cut from sill support to after jack receiver. clean out whats in there , treat, reweld and do the rd panel. you should do the rd panel on both sides of the car.
Lo-Fi Version | Time is now: 26th December 2024 - 12:50 PM |
