Door handles broken |
dheinz |
Sep 11 2017, 04:04 PM
cross member Group: Members Posts: 122 Joined: 7-August 03 From: Pittsburgh, PA Member No.: 995 |
OK.... Time to sell one of my 914 parts cars. The car has been sitting in a field for 10 years. Both door handles have snapped off. Do I have to break a vent window or is there a trick to opening the door? I have inflated the tires and need to move the car to power wash it before posting an ad. |
GaroldShaffer |
Sep 11 2017, 04:13 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
so the flapper has broken off or the complete handle? If the handle is gone stick your finder in the were the handle was. Near the edge towards the rear of the door you will see the 'U" part of the door latch. Push that in while pulling on the door and it should open. I can post a picture in a little while of what I am talking about.
In the past I have been able to kindof force the window down with my hands enough to get a coat hanger between the glass and targa top and reach the inside door handle to pull it open. |
dheinz |
Sep 11 2017, 04:50 PM
so the flapper has broken off or the complete handle? If the handle is gone stick your finder in the were the handle was. Near the edge towards the rear of the door you will see the 'U" part of the door latch. Push that in while pulling on the door and it should open. I can post a picture in a little while of what I am talking about. In the past I have been able to kindof force the window down with my hands enough to get a coat hanger between the glass and targa top and reach the inside door handle to pull it open. Thanks Garold. The flaps are gone but the key slot chrome holders are still there. I don't want to break the vent window. I will try the coat hanger trick... |
poorsche914 |
Sep 11 2017, 06:31 PM
T4 Supercharged Group: Members Posts: 3,093 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
If you can somehow manipulate the rear targa latches, you could lift the top enough for easier access to roll a window down or even release the front latches.
(IMG:style_emoticons/default/driving.gif) |
bbrock |
Sep 11 2017, 09:20 PM
It's slightly brutal, but you can slip a pry bar under the targa top near a latch and gently pry up enough to bend the latch bracket a little. Then you push down on the top and, if you are lucky, the hook swings away and disengages. You'll have to do both sides to take the top off. You can remove the latch and tap it back to shape with a hammer afterward. Don't ask me how I know this. (IMG:style_emoticons/default/screwy.gif)
rhodyguy |
Sep 12 2017, 10:30 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,102 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Parts car. Vent window glass is readily available. Sooner that than damaging the roll up window and all that entails. Do slim jims work on 914s?
dheinz |
Sep 12 2017, 12:22 PM
If you can somehow manipulate the rear targa latches, you could lift the top enough for easier access to roll a window down or even release the front latches. (IMG:style_emoticons/default/driving.gif) Lucky me, the rear targa latches were not latched. With some gentle persuasion and two 2x4s I was able to release the front latches. The car is now open and rolling. It will be up for sale soon. Attached thumbnail(s) |
76-914 |
Sep 12 2017, 05:28 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,514 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
post the VIN # here so that Sir Andy can sleep nights. (IMG:style_emoticons/default/biggrin.gif)
dheinz |
Sep 12 2017, 05:51 PM
All of my vin#s posted here years ago. |
Lo-Fi Version | Time is now: 20th June 2024 - 06:04 AM |
