Door Window Trim, Door Trim Disassembly/Assembly |
Highland |
Sep 21 2017, 02:51 PM
Senior Member Group: Members Posts: 529 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Can someone tell me how to remove this door trim, the piece that holds the felt against the window and the rubber between the door and wndow?
Seems to slide a little, but I can't see how it's attached and thought better to ask then break something by forcing too much. |
arne |
Sep 21 2017, 03:18 PM
Serial Rescuer of old vehicles... Group: Members Posts: 770 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
There should be three screws that go through the fuzzy into the door. Once those are removed, the aluminum trim can be pushed down. I clips to the door edge from below.
Mikey914 |
Sep 21 2017, 11:27 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Occasional;ly they are rusted out. and can be drilled if necessary.
If you want new trim I have it here- http://shop.914rubber.com/91453195910-Door...91453195910.htm I have both early and late as well as all the new fuzzes and rollers for the windows. Attached thumbnail(s) |
barefoot |
Sep 22 2017, 07:12 AM
Senior Member Group: Members Posts: 1,334 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
those 3 little screws on each door were the only screws/bolts on the entire car that did not come off easily, I finally gave up before I ruined a new paint job.
DRPHIL914 |
Sep 22 2017, 07:47 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
oh I need 2 of these mark! along with all the stuff I PM you about the other day-
Lo-Fi Version | Time is now: 26th December 2024 - 07:36 PM |
