Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
As called out in the title.
Did you a bunch of replacement glass for the mirrors, $9.14 each. Will be $15 after the GB Have a few other goodies I'm butting together here too so you could combine. Just bump the thread if you are interested. Pics to follow Sunday, but you get the idea. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Are you making both sizes. I need about 6 early and 2 late.
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
Interested in a couple sets
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
+1 on glass.
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
I'll take one for a '72. Not sure if that's early or late
bob |
Member ![]() ![]() Group: Members Posts: 146 Joined: 8-January 03 From: Va. Member No.: 109 Region Association: None ![]() ![]() |
I'm in for 2 sets.... 1 early and 1 late.
-bob |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Mark, Are these flat or convex mirrored glass?
bretth |
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region ![]() |
One for my 75 please.
markhoward |
Member ![]() ![]() Group: Members Posts: 379 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California ![]() ![]() |
Im in..
Mikey914 |
These are flat not convex. I made off the 75 I have and it fits the 73.
So where is the cut off? I had not noticed early and late. I'm assuming 72 or earlier? I'll have to procure a sample to check. If they are smaller I can accommodate fairly easy. Mark |
Jett |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,646 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest ![]() ![]() |
I could use 2 small and 2 large
strawman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California ![]() ![]() |
Put me down for one! What else new are you going to release!?!?
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
ill take one and combine it with the $40 GB
mepstein |
These are flat not convex. I made off the 75 I have and it fits the 73. So where is the cut off? I had not noticed early and late. I'm assuming 72 or earlier? I'll have to procure a sample to check. If they are smaller I can accommodate fairly easy. Mark Early is a sharp, right angle for the chrome arm. About a 1/4” smaller glass. Different plastic spacer and trim. |
Mikey914 |
Thanks for volunteering a sample. For the record, do you know the production breaks on these?
Either way I'll have both. Thx Mark |
Mikey914 |
Some pictures on these as well as the assembly procedure. Not the plastic "ring" is best bent in from the longer sides to remove.
Attached thumbnail(s) ![]() |
Mikey914 |
Glass removed
Mikey914 |
Glass seated in the base - no retainer "ring" installed.
Mikey914 |
Retainer installed
Mikey914 |
I will be sending out codes here late today. I also have 3 other GBs running so you can combine.
They are - - The CHT for D jet PN 0280130012 -shift bushings GB -GB for Mirror - Late -GB for the positive terminal block that will be launching tonight and I'm working on a complete cable option. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:52 AM |
