throttle cable |
throttle cable |
JFG |
Oct 6 2017, 11:13 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I bought this from a german trader, can someone confirm it is a 914 cable?
Secondly if it is how does it fit? My original was not intact and i lost the pictures from disassembly. |
JFG |
ChrisFoley |
Oct 6 2017, 11:58 AM
I am Tangerine Racing Group: Members Posts: 7,968 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Looks right. The threaded end goes thru firewall throttle tube at the firewall all the way to the front of the cockpit. It requires a female ball socket threaded end to connect with the pedal bellcrank. The end with crimped plain rod requires a 8mm od barrel nut to connect with the carb linkage. |
JFG |
Oct 6 2017, 01:16 PM
Thanks for that I'll have to search the boxes for the end at the pedal.
Lo-Fi Version | Time is now: 26th December 2024 - 11:45 PM |
