Sort of O/T, how to remove oil stains of headers ? |
porschetub |
Oct 7 2017, 02:40 PM
Advanced Member Group: Members Posts: 4,754 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
When my oil cooler let go I had oil on the LH side header which burnt off leaving a lot of staining on my ceramic coating.
Tried several times to get it off but no real results,about to try acetone after that I'am lost for idea's. TIA |
mepstein |
Oct 7 2017, 02:47 PM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lacquer thinner
porschetub |
Oct 7 2017, 02:54 PM
DM_2000 |
Oct 7 2017, 05:53 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
I'd see what the coating people say. I'd be tempted to use oven cleaner to remove carbon.
porschetub |
Oct 8 2017, 05:47 PM
I'd see what the coating people say. I'd be tempted to use oven cleaner to remove carbon. Don't know who did the coating,won't be putting on what you suggested sorry too expensive to risk that,had some success with the thinners but not easy...baked on (IMG:style_emoticons/default/sad.gif) . |
'73-914kid |
Oct 8 2017, 10:08 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Ceramic coatings are porous unfortunately.. they stain extremely easily, and can be almost impossible to clean once the oil is baked on..
At least they're on the bottom side of the car.. |
Maltese Falcon |
Oct 9 2017, 12:03 AM
Advanced Member Group: Members Posts: 4,894 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
If it is a JetHot style coating, and you haven't driven + baked it on the coating for too long : I have used a mild dish soap solution with a fine scotch brite pad. You are basically just burnishing down the coating very finely, but really depends how long it was driven and baked on.
porschetub |
Oct 9 2017, 04:44 PM
If it is a JetHot style coating, and you haven't driven + baked it on the coating for too long : I have used a mild dish soap solution with a fine scotch brite pad. You are basically just burnishing down the coating very finely, but really depends how long it was driven and baked on. Thanks Marty,emailed the OP and he just replied saying it is that style of coating,not driven much like this, (IMG:style_emoticons/default/beer.gif) . Will report back when I'am on jackstands again (IMG:style_emoticons/default/biggrin.gif) . |
Lo-Fi Version | Time is now: 26th December 2024 - 08:46 PM |
