> Is the injector resistor pack the same for 1.8/2.0, 1975 914 (tuns out to be the speed limiter )CA only
rfinegan
post Oct 8 2017, 05:14 PM
I am converting my 1.8 to a factory 2.0 with an engine swap with harness and ECU. Will my resistor pac from my 1.8 work for the 2.0?
BeatNavy
post Oct 8 2017, 05:31 PM
Not completely sure of the question. Are you going to D-Jet for the 2.0? D-Jet doesn't use a resistor pack like L-Jet on the 1.8.
rfinegan
post Oct 8 2017, 05:38 PM
Yes it is a d jet, I have a white wide blade connector near the battery that i am trying to determine what it plugs into. Look like the same plug for the resistor block??? (IMG:style_emoticons/default/confused24.gif)
Robert
My 75 1.8 resistor block did plug into the socket, so I'm confused ? It was thinking the Djet did not use resistors
-Robert
JeffBowlsby
post Oct 8 2017, 06:00 PM
914 Wiring Harnesses
The one wire single wide blade should be in a single pole box housing. It connects to the cyl head temp sensor near cyl 3.
rfinegan
post Oct 8 2017, 06:07 PM
its the first connector coming of the ECU wiring harness
rfinegan
post Oct 8 2017, 06:31 PM
Speed limiter? Do i have to find one or will it work without it installed?
JeffBowlsby
post Oct 8 2017, 06:38 PM
OH. You have an FI harness from a 1975-76 2.0L CA-only model, which includes the speed limiter accessory. Even though it has the same connector as an L-jet resistor pack, DO NOT PLUG IN THE RESISTOR PACK. You can run without the speed limiter, just leave that branch dangling with nothing connected
rfinegan
post Oct 8 2017, 06:40 PM
Thanks Jeff/Rob...
DM_2000
post Oct 8 2017, 06:44 PM
Speed limiter as in road speed or engine rev limiter?
JeffBowlsby
post Oct 8 2017, 09:08 PM
Rev limiter. It cuts off the fuel above a certain RPM as an emissions device.
MartyYeoman
post Oct 8 2017, 09:15 PM
Wow, The depth of knowledge around here is truly astounding. (IMG:style_emoticons/default/smilie_pokal.gif)
Dave_Darling
post Oct 9 2017, 10:19 AM
914 Idiot
Porsche, or Bosch, noticed that it wasn't such a good idea to cut the spark to limit the RPMs when you have a catalyst in the exhaust. Because cutting the spark means you have fuel still going through the engine, and the catalyst gets nice and hot... Wanna guess what can happen there?
So they implemented the rev limiter by cutting the fuel. I believe the limiter interrupts the signal from the trigger points when they start signaling too quickly.
--DD
- Lo-Fi Version Time is now: 27th December 2024 - 05:05 AM
