Flywheel shims, Where to get them |
914fun |
Oct 18 2017, 01:26 PM
Member Group: Members Posts: 107 Joined: 22-June 08 From: Joplin MO Member No.: 9,201 Region Association: Southwest Region |
I need three .30mm shims for the end play. The three that I have are .31 and gives me almost 0 end play. I see them at Auto Atlanta but they want almost 20.00 for each of them. Seems like a lot when the type one shims are only 3.00 so if someone has a better source for them please let me know.
flyer86d |
Oct 18 2017, 02:06 PM
Member Group: Members Posts: 451 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Try Retro Automotive in Clairmont, New Hampshire. A huge warehouse full of used Porsche parts.
Charlie |
McMark |
Oct 18 2017, 02:25 PM
http://www.gowesty.com/product-details.php?id=24288
Also, the VW dealer can get them. 021 105 281 |
Morrie |
Oct 18 2017, 02:53 PM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
Mark, Have there been any reports of issues with the shim material hardness like we are now seeing on 616 motors (356/912). Reputable shops (Cranky Jack for one) and DIY folks are seeing some cases where these wear, causing drastic changes in end play in short periods of time, and damaging the engine. Just curious... |
BillC |
Oct 18 2017, 03:57 PM
Senior Member Group: Members Posts: 574 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Any chance you could find a single .28mm shim?
Hmm, maybe not. However, AA lists a .24mm shim, but that might be too much endplay. |
McMark |
Oct 19 2017, 06:41 AM
Mark, Have there been any reports of issues with the shim material hardness like we are now seeing on 616 motors (356/912). Reputable shops (Cranky Jack for one) and DIY folks are seeing some cases where these wear, causing drastic changes in end play in short periods of time, and damaging the engine. Just curious... I haven't seen or heard anything bad yet. (IMG:style_emoticons/default/confused24.gif) |
Morrie |
Oct 19 2017, 09:14 AM
Mark, Have there been any reports of issues with the shim material hardness like we are now seeing on 616 motors (356/912). Reputable shops (Cranky Jack for one) and DIY folks are seeing some cases where these wear, causing drastic changes in end play in short periods of time, and damaging the engine. Just curious... I haven't seen or heard anything bad yet. (IMG:style_emoticons/default/confused24.gif) Just wanted to share, since this has been an issue for the 356/912 community. Here are a couple threads from the 912BBS if anyone is curious. http://www.912bbs.org/vb/showthread.php?50...t=shim+hardness http://www.912bbs.org/vb/showthread.php?45...light=blanching I know these are different parts, but probably similar sources and processes. |
SirAndy |
Oct 19 2017, 10:39 AM
Resident German Group: Admin Posts: 41,937 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Reputable shops (Cranky Jack for one) and DIY folks are seeing some cases where these wear, causing drastic changes in end play in short periods of time, and damaging the engine. How exactly would a shim "wear" ??? (IMG:style_emoticons/default/confused24.gif) |
Morrie |
Oct 19 2017, 10:44 AM
Reputable shops (Cranky Jack for one) and DIY folks are seeing some cases where these wear, causing drastic changes in end play in short periods of time, and damaging the engine. How exactly would a shim "wear" ??? (IMG:style_emoticons/default/confused24.gif) There's details in the threads I posted. I am not a SME, just a messenger here sharing information. Could it be soft material compressing over time due to pressure and the ongoing end play shift working on it also? All I know is that folks that do this for a living are spreading caution, so wanted to give a little PSA here. |
McMark |
Oct 19 2017, 11:16 AM
The flywheel shims aren't just shims. They are sandwiched between the flywheel (rotating) and the main bearing (stationary). That's the reason three shims are specified. With three shims there should be enough lubrication to minimize friction between the Bearing-Shim-Shim-Shim-Flywheel assembly.
But a certain level of hardness is necessary for the shims. Too soft and even with proper lubrication they can wear away to nothing. Even high mileage original shims show wear. I stopped reusing shims awhile ago just for this reason -- no guarantee they're still flat and consistently thick. |
Lo-Fi Version | Time is now: 22nd December 2024 - 05:19 AM |
