Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
We will be making a rear trunk lock repair kit that replaces the rubber base, the outter bezel and the lock button. It will allow you to use your lock (no re keying) to make the one you have look brand new.
Who's in? |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I’ll take a couple. Thanks!
UROpartsman |
Member ![]() ![]() Group: Members Posts: 292 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None ![]() ![]() |
Great idea, what a coincidence that Sierra Madre and AA just started selling this exact product from URO yesterday: http://www.914world.com/bbs2/index.php?showtopic=321825
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.uroparts.com-19288-1515541178.1.jpg) |
Mikey914 |
Yep (IMG:style_emoticons/default/biggrin.gif)
Will be made in USA and better materials for less! |
walterolin |
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States ![]() |
One set.
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,682 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Will be watching this....
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Great idea, what a coincidence that Sierra Madre and AA just started selling that exact product yesterday: http://www.914world.com/bbs2/index.php?showtopic=321825 (IMG:http://www.914world.com/bbs2/uploads_offsite/www.uroparts.com-19288-1514584183.1.jpg) So judging by your stats, you’ve trolled 914Rubber’s posts 15 times? (IMG:style_emoticons/default/confused24.gif) You’ll find we’re all pretty loyal and his parts don’t have a 50% failure rate so... |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/smile.gif) Another great idea/ product; thanks for making these. Put me down for one
gothspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None ![]() |
Wow! (IMG:style_emoticons/default/idea.gif)
Mikey914 |
We will actually machine these from steel not pot metal. This is what pot metal does.
If we polish and plate the steel it will be a much better product. It is possible we to make in stainless, however it will drive the price up, as material is much more expensive in the correct alloy. (IMG:style_emoticons/default/idea.gif) Attached thumbnail(s) ![]() |
914_7T3 |
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,854 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California ![]() ![]() |
Please add me to the group buy for 1 please!
jcambo7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest ![]() |
What material is the stock one made out of?
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
Materialwise yes stainless is of course more expensive than mild steel.
Machining wise the cost should be the same if you use a good machinist, they're both "soft" materials. Where they differ is the finish, the stainless can be just polished to an ok surface or a brushed satin look where the mild steel needs to be chromed. The chroming process should be as expensive as polishing the stainless if not even more expensive weighing up some of the added stainless material cost. This is the sort of stuff I do on a daily basis as my profession, good luck Mark. (IMG:style_emoticons/default/smile.gif) |
Mikey914 |
The machining will not be an issue as we have our own shop, the 304/5 machines much easier, but will be best if we do 316, a little harder but will not brown. One of those, if your gonna do it do it right things.
I'm thinking I may have 2 flavors, the plated and the stainless. |
Mikey914 |
rmdinmd |
Member ![]() ![]() Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States ![]() ![]() |
I am in for one.
sithot |
Member ![]() ![]() Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None ![]() ![]() |
What material is the stock one made out of? Not 100% sure of content on all, but the factory had at least some that were zinc diecast. I'm in. THANK YOU. Always up for support of those who are aiding the hobby, especially if they are a manufacturer. Manufacturing isn't as easy as it looks. |
live free & drive |
Member ![]() ![]() Group: Members Posts: 159 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None ![]() ![]() |
Why not have the stainless electropolished - it does any deburring necessary along with a pretty nice finish that will never rust because all surface carbon has been removed.
It is cheaper/faster than plating. I you turn the outer bezel/button surfaces to a pretty high RA you will get a nearly chrome appearance. https://www.google.com/search?rlz=1C1SAVU_e...37FQcN8WxX6UqM: |
brownaar |
Member ![]() ![]() Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None ![]() |
I'll take a set.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
We will actually machine these from steel not pot metal. This is what pot metal does. If we polish and plate the steel it will be a much better product. It is possible we to make in stainless, however it will drive the price up, as material is much more expensive in the correct alloy. (IMG:style_emoticons/default/idea.gif) I know that hand ! I have one just like it. LOL Or is that a new URO part ? Bruce |
Lo-Fi Version | Time is now: 26th June 2024 - 02:57 PM |
