Dck356 |
Newbie ![]() Group: Members Posts: 20 Joined: 9-April 12 From: Davidson, NC Member No.: 14,355 Region Association: South East States ![]() |
Hey guys. I'm pretty sure I need a new oil cooler. Just changed the seals and oil is leaking from the bottom of the cooler - nothing leaking between the cooler and the case... so the new seals aren't leaking. Any reco on what/where to buy? I can spend $150 on an oem version or $50 from AA performance. Any thoughts are much appreciated. Thanks in advance!
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Hey guys. I'm pretty sure I need a new oil cooler. Just changed the seals and oil is leaking from the bottom of the cooler - nothing leaking between the cooler and the case... so the new seals aren't leaking. Any reco on what/where to buy? I can spend $150 on an oem version or $50 from AA performance. Any thoughts are much appreciated. Thanks in advance! I have at least a dozen of them I would would sell for $20 each. I worked for an oil cooler company for over twenty years. Oil coolers are not all built the same. AA is not an oil cooler company. Can they produce a graph showing the amount of BTU heat dissapation compared to an original cooler? If not do not waste $50. What engine is it ? The stock coolers are barely enough for a stock 2.0 on a hot day. You would just need to clean any of the used coolers. Do you have an oil temp gauge to know if a cooler is as effective an an OEM ? If not it is big gamble. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:50 PM |
