Tips on removing rear rotors |
tod914 |
Jul 9 2003, 02:09 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
rear brakes off now. The 2 screws/bolts that secure the rotor uhhh wont budge. I dont want to strip the slot in the head. Any tips? my big screw driver aint cutting the mustard.
JWest |
Jul 9 2003, 02:19 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Impact screwdriver (you hit with a hammer). Works everytime for me.
tod914 |
Jul 9 2003, 02:42 PM
Ok cool james - back off to sears again (IMG:style_emoticons/default/MDB2.gif)
rhodyguy |
Jul 9 2003, 04:54 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
penetrating fluid, squirt the back sides of them too. to break the rust bond i have a small steel chisel that i put in the screw head and wack it repeatedly. if one should turn out to break, go to the back side and see if you can grab it with vise grips and continue to turn it through. take your time, spray, tap. spray tap.
kevin |
TheCabinetmaker |
Jul 9 2003, 05:10 PM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Impact screwdriver is the way to go but make sure your tips
are impact quality( hardened steel). cheap imports will break before the screws!!!!! Read the directions on how to use it. |
Brad Roberts |
Jul 9 2003, 06:22 PM
I use cheap screwdrivers that have a provision for a 10mm wrench up near the handle. I push really hard and twist the 10mm wrench.
The other thing I do: Hit them with a flat faced chisel before you even try to twist the screws.. or just hit them flat with a hammer. This helps "shake" them loose. I honestly have never used a impact screwdriver on them.... but I know most people use them. B |
tod914 |
Jul 10 2003, 04:20 PM
wow that impact screw driver was the ticket. couldnt believe how easy it was using that . thanks
Brad Roberts |
Jul 11 2003, 04:16 PM
Ha ha.. which is why I dont use them... You dont normally actually need them.
B |
Lo-Fi Version | Time is now: 28th September 2024 - 09:09 AM |
