80cap |
Member ![]() ![]() Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None ![]() |
Ok, I set the valves to zero lash the engine has a very noticeable rattle. I think I read that they will sound like a bucket of bolts but I don't recall the sound level being this loud. I rechecked the clearance twice. The engine pulls real strong. I'm all ears!
Brian |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
shouldnt really sound like a bucket o bolts. do you have hydraulic lifters? If so, and it's been a while since the car was driven, it can sound really noisy till the lifters inflate with oil
80cap |
Solid lifters.
Brian |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Should sound very smooth. No rattles.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I don't understand zero lash with steel pushrods ,makes sense on a hyd lifter motor but on a solid tappet motor what happens when the engine heats up and expands width wise ?,surely the expansion rate would be different between steel and alloy pushrods ???.
I'am old but I never stop learning (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Case ans heads are aluminium, they expand more than steel.
craig downs |
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California ![]() |
Check the clearance between the rockers and spacers. If it is a lot then that makes noise to.
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
Case ans heads are aluminium, they expand more than steel. (IMG:style_emoticons/default/agree.gif) Jake explains it that way....with lash at zero with engine cold it'll open up to .004-.006 with the engine hot, so you'll hear a bit of the usual ticking from the valves especially with thin oil....BP 20/50 may keep it a bit quieter... |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
When should you use 0 valve lash vs the .006/.008?
80cap |
Only with chrome moly push rods.
I going to check again for a loose rocker today before cars and coffee. Brian (IMG:style_emoticons/default/headbang.gif) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Running .006 on steel PR will make them noisier.
They are noticeably noisier cold and you can still hear it warm, especially if you have a quiet exhaust. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:39 AM |
