914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
When I was gathering parts to rebuild the two distributors I have, I found the new Bosch condensers with the correct numbers were to short. I did find some NOS ones that were long enough. I knew that there must be a better solution, besides I did not like the way the wire came all the way across the distributor. I kept looking at Bosch condensers until this one popped up. It is designed for the 912 distributor. There are two versions one with the square hole and the round hole. Only the round hole will work. Since then I have found a couple more versions that will work also. You can make a custom fitted wire from the distributor to the coil. I like the cleaner look. Pictures show NOS factory setup first then the revised version.
Attached image(s) ![]() ![]() ![]() ![]() |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Very interesting, but not sure I understand the solution. I think you have changed the mounting location but not at all sure what else is new. Dark wire is gone. What condenser?
914Sixer |
Condenser is moved from being mounted over on the vacuum canister to right at the plug where it needs to be.
MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
Looks cleaner, but doesn't the condenser now interfere with the 3-4 tin-work once installed? (IMG:style_emoticons/default/confused24.gif)
914Sixer |
I get a 0 on checking that fact.
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
I may have a box full of NOS condenses and such if there is a need for them.
Lo-Fi Version | Time is now: 26th June 2024 - 01:55 AM |
