nino1964 |
Newbie ![]() Group: Members Posts: 2 Joined: 29-April 18 From: Chattanooga TN Member No.: 22,084 Region Association: South East States ![]() |
Does anyone no how to install this clip on the rear brake caliper piston dust but?
Thanks Nino Attached thumbnail(s) ![]() |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
There should be a lip at the base of the rubber boot, and there is a ridge inside the caliper bore. After placing the ring around the base of the boot, than compress the ring, overlapping the edges, push with a blunt tool, into the bore .
nino1964 |
There should be a lip at the base of the rubber boot, and there is a ridge inside the caliper bore. After placing the ring around the base of the boot, than compress the ring, overlapping the edges, push with a blunt tool, into the bore . Thanks for the reply. I did find a groove on the base of the boot and ridge on the piston. Do you need to retract the piston completely in the caliper housingto find the ridge inside the bore? If so is screwing cw the proper method for retracting the piston? |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Fit it properly or the you can rip the piston boot....take care.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
PMB has a very detailed video at their website. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 11:25 AM |
