Ah, fresh air |
Ah, fresh air |
Amphicar770 |
May 1 2018, 08:02 PM
Senior Member Group: Members Posts: 1,205 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
One of the things I admire about the 914 is that every piece seems to serve a purpose.
One if the things troubling me on my 2.0 was the VW smell in the cabin. I knew exhast and exchangers are good but it was still there. Turns out that while the rubber seals around the engine tins are all new, a section on drivers side kept popping off. I thus glued it with some 3M weather strip adhesive. Nice long drive today, nothing but fresh air. |
maf914 |
May 2 2018, 04:05 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
That is interesting. The air that passes through the heat exchangers on the way to the cabin begins at the engine cooling fan and shroud. I thought that this would always result in some odor from the engine compartment being passed on to the cabin. I was aware of a faint mechanical/oil odor and blamed my dual carbs. Perhaps I need to replace the engine tin to body seals. (IMG:style_emoticons/default/idea.gif)
Lo-Fi Version | Time is now: 24th September 2024 - 01:29 PM |
