Engine Skipping Feeling, Thoughts? |
Ross |
May 7 2018, 12:47 PM
Member Group: Members Posts: 90 Joined: 17-August 16 From: Charlotte, NC Member No.: 20,304 Region Association: South East States |
Hi Everyone,
RE: 1972 914 1.7L Just wanted to get you all's thoughts on an issue I'm having. Here's my observations: 1. When cruising (not accelerating or decelerating) the car skips and almost feels like it is cutting off. It doesn't matter the speed. 2. It accelerates fine and when decelerating it is fine. 3. I replaced the ignition wires, plugs and coil last weekend. No improvement. 4. I had electronic ignition put in about a year and a half ago. Not sure if that could be the culprit. Any help/thoughts would be much appreciated. Thanks |
Beebo Kanelle |
May 7 2018, 12:50 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
I had the same situation awhile ago and I replaced throttle position sensor board. Problem solved.
https://shop.914rubber.com/Porsche-914-Thro...20-914TPS20.htm |
thelogo |
May 7 2018, 01:11 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I had the same situation awhile ago and I replaced throttle position sensor board. Problem solved. https://shop.914rubber.com/Porsche-914-Thro...20-914TPS20.htm (IMG:style_emoticons/default/agree.gif) Replaced every last trace of fuel injection related parts with webber Carbs. Problems was definitely solved (IMG:style_emoticons/default/agree.gif) |
Rand |
May 7 2018, 03:39 PM
Don't swap to carbs. Do check the TPS.
TheCabinetmaker |
May 7 2018, 04:27 PM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Another for the tps. And, another for keeping the djet.
stevend914 |
May 7 2018, 05:05 PM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
Don't swap to carbs. Do check the TPS. (IMG:style_emoticons/default/agree.gif) I had the same problem. Replaced the TPS and problem solved. |
dr914@autoatlanta.com |
May 7 2018, 05:08 PM
914 Guru Group: Members Posts: 8,052 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
ross just unplug the switch (under the throttle valve, yes it gets dirty) and see if the problem goes away, what you may notice is a hesitation upon initial acceleration and a pop in the pipe when letting off. If this seems to solve then remove the throttle body, pop the cover off the switch and clean with tuner cleaner (contact oel)
Other than that the ground leads at the back of the block may not be making contact Hi Everyone, RE: 1972 914 1.7L Just wanted to get you all's thoughts on an issue I'm having. Here's my observations: 1. When cruising (not accelerating or decelerating) the car skips and almost feels like it is cutting off. It doesn't matter the speed. 2. It accelerates fine and when decelerating it is fine. 3. I replaced the ignition wires, plugs and coil last weekend. No improvement. 4. I had electronic ignition put in about a year and a half ago. Not sure if that could be the culprit. Any help/thoughts would be much appreciated. Thanks |
Ross |
May 8 2018, 01:41 PM
Thanks everyone great information!
Lo-Fi Version | Time is now: 21st September 2024 - 07:00 PM |
